disabling VTC?
disabling VTC?
I read on Craig Brace's page that you can disable the VTC by running a ground to the VTC wires, exactly which wires are these though it doesnt really tell, there are 2 wires running from the big harness. to the VTC silenoid, Would I need to ground both or just 1? >_> if so which 1?
Originally Posted by todamax
yellow!!!! want me to go take a pic of mine? I've not removed the tap I put on there yet. Finished the VTC rebuild yesterday..
well I did it and it seemed to make the sound a bit less appearent but it was still there, So I reconnected it and left it as is.
I grounded mine at 230,000 miles and it still had a little lifter knock.
Then I added a quart of resilon at the next oil change and it sounds soooo
quiet.Only a little tap on start up. Seems to idle a bit radical
but no more time bomb ticking.
Originally Posted by bananaX
260,000 KM so like
160k M?
160k M?
The last time I heard a story like this, it wasn't the VTC's making noise. It was the timing chain tensioner on the front/left cylinder head. The guy grounded the VTC's properly but the noise remained. He didn't know what to make of it so he just shrugged and went about his daily business. One day the tensioner completed its road to failure and threw the chain. It destroyed the valves... Your car is about the right mileage for this to be an issue, have it checked or start planning on a blown engine.
that sounded like me
grounded the vtcs and still had that ticking time bomb noise
replaced the tensioners and put it back together
1000 miles later and boom timing chain goes
have it checked out
hmmm. how loud is the tensioner sound though?
I mean my sound litteraly sounds like
as i accelerate ONLY,
vroom click click click click click but its not a fast click, and it doesn't really go up so much with rpm which is why I would doubt the tensioner
Originally Posted by ghostmax
so we should worry about replacing the tensioners and chain before it blows up?
If it was me, yes. If I still have the car at 150K I will do them then. I've seen to many posts where the mileage hits 160-180K and *BOOM* goes a timing chain. I've got an extra VE engine that I pulled a VTC from and its tensioners are pretty worn, they have 163K on them. They are bad enough that if I had seen them in an operating car, I'd repalce them. Of course there is no way to check the chain...
My max spent its first 9 years as a city car doing stop & go, had 58K miles when I bought it 4 years ago and now its at about 101K. I have the ticking noise and was planning to ground the VTCs soon, so I'll see if the noise remains once I do.
Does the chain tensioner go bad with both age and milage?
It actually wears, so my $0.02 is mileage. I can get pics of the one from my 163K engine later this week (its at my parents house).
All i can find is how to rebuild them(which i plan on doing in the next few months)but i would like to disable them for now,i just need to know which wires to ground and where they are located. Any help would be appriciated thanks in advance Jesse.
Matt93SE
Apr 8, 2018 09:23 AM
rbaker100
Aug 31, 2015 11:09 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
