Need help with Remote Start wires!
Aug 19, 2006 | 06:19 PM
I have used craig Braces web site to find out all of my wire connections but I cant find 2 wires.
What two wires must be powered to crank the engine ?
Thanks Guys!!
Aug 19, 2006 | 07:29 PM
the 2 that glow when tested with a test light and the ignition switch in start.
my colors didn't match either.
Aug 19, 2006 | 08:00 PM
there are 5 wires in the main ignition harness
+12V
ACC
IGN
Start1
Start2
I can't remember the colors off hand, but it'd be pretty easy to test. If not, search on here, I've posted a pretty detailed writeup that has everything you need (not on my site though).
Aug 20, 2006 | 12:14 AM
or email and i will send you a e-manuel that should have everything and a lot more just put "alarm" in the subject title
Aug 20, 2006 | 08:49 AM
Thanks Guys I took the spark plug wires off and cranked the engine while testing volts on each terminal and I found the two wires that need to be hot !
Does anyone know if the 89 se maxs were prewired for the electric trunk pop?
I am installing one and would like to know
Thanks !!!!!!!1
Aug 20, 2006 | 09:23 AM
Ok I am trying to find a easy place to tap the light blue unlock wire and the Grey/red lock wire ......I know a good place would be the door lock timer module but I forgot were the stupid box is located Could someone tell me where it is exactly ..........
I can't believe I hooked up the remote start easier and faster than finding the stupid lock unlock wires !!!
Thanks Guys!!
Aug 20, 2006 | 03:08 PM
lock module is on the right of the steering wheel
Aug 20, 2006 | 04:15 PM
Well I couldnt get a wire inside the to work to lock unlock the doors so I tapped the wires in the door and ran a wire into the car..... ....But the good news is I got the lock unlock to work and the remote start works !!
I still have to wire the trunk pop relay and and mount the trunk pop solonoidin the trunk area but I'll save that for next weekend!!
