Noisy belts?
Old Oct 6, 2006 | 01:37 PM
KeithD's Avatar
Noisy belts?
My car screeches and squeels when it starts up, and then after warmed up, the belt(s) seem to be quite noisy. Any tips or tricks to fixing this? Can they be replaced fairly cheap? I know this an extreme noob question, but what is the best way to change them, they look burried in the engine bay. (VE)
Old Oct 6, 2006 | 01:41 PM
Greeny's Avatar
¯\(°_o)/¯
Sounds like they need replaced or just tightened...Be careful not to tighten them too much,if you go that route..
89blackse's Avatar
"and falling like a rock"
belt dressing
Old Oct 6, 2006 | 01:45 PM
Greeny's Avatar
¯\(°_o)/¯
A little bigger..
Old Oct 6, 2006 | 01:46 PM
Greeny's Avatar
¯\(°_o)/¯
Originally Posted by 89blackse
belt dressing
Blinker fluid?...
Old Oct 6, 2006 | 06:08 PM
Maxima Man's Avatar
you have never heard of belt dressing............. its real stuff I use It and it works well!
Old Oct 6, 2006 | 06:48 PM
Cliff Clavin's Avatar
Way out West
just put on some gatorback belts. I have them on my car and never a peep.
Old Oct 7, 2006 | 03:22 AM
89blackse's Avatar
But then you (Green) reminded me that our cars have (better) manual belt tensioner, which should always be adjusted before using any belt dressing.
However if your gf has a POS saturn which blows the auto tensioner once a year, belt dressing is your fawking best friend.
Old Oct 7, 2006 | 06:06 PM
Will's Avatar
Keith, if you go to Canadian Tire, they will have Motomaster Belt Dressing, but I personally do not recommend using it. The pulley bearing for the AC belt sometimes goes bad on 3rd gens, but if the belts are brittle-looking and cracked, just replace them. I like OEM belts.
Old Oct 9, 2006 | 03:22 PM
KeithD's Avatar
After some inspection I was pleased to find the belts where actually in good condition. So I broke out the 12 mm wrench and after some adjustment to the tension my squeel is gone, as well as general belt noise has been reduced. THanks to all!
Old Oct 9, 2006 | 08:43 PM
Maxteca's Avatar
Put on some new belts. That shoul fix it.
05' MaximaMan
Oct 8, 2017 06:36 PM
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
markevans999
Oct 25, 2015 08:27 AM
homewrecker
Sep 24, 2015 07:01 PM
2kmaximel
Sep 24, 2015 03:55 PM
