New exhaust and missing low end torque
Old Dec 13, 2006 | 09:48 PM
  #41
sonicii's Avatar
Originally Posted by Hollywood!
To please d00df00d... ITS NOT BACKPRESSURE FOR THE DEAR SWEET LOVE OF GOD
I feel your pain.. backpressure is bad. But it's not the flow of exhaust that causes the scavening effect, it is the pulse of high pressure when the exhaust valve opens, followed by the pulse of low pressure when it closes. Idealy you want the low pressure pulse to meet at the collector when the exhaust valve of the next cylider opens, this helps 'pull' the exhaust out of the next cylinder. On a stock system, this happens reasonably low in the rev range, by opening up the exhaust system, the exhaust gasses move slower for a given RPM, therefore the scavenging effect occurs at higher revs.
In a nutshell -
the advantage of a smaller system is lower RPM torque, but excessive backpressure at higher RPM (backpressure is bad).
A larger system reduces the backpressure at high RPM (more power), but also reduces the torqure at lower RPM.
The only reason the engine runs like crap without any exhaust system is because it's cam is designed to suit the standard exhaust setup.
Old Feb 9, 2007 | 04:40 PM
  #42
speedfreak4996's Avatar
Originally Posted by Cliff Clavin
What is all the complaining about?
First off, the VE isn't designed for low end torque, it was designed for the upper end. If you want low end torque, get a VG. Most people that have driven both will tell you that a VG feels stronger in low rpms.
The aftermarket exhaust systems are set up to increase hp and decrease 1/4 mile times (go faster). This is especially true with a VE.
If you aren't happy with more hp, better mpg and a car that is faster when pushed, go back to stock.
Isn't this the purpose of vtc? ve has 190ft lbs behind it.. more than vg if im not mistaken. vtc is supposed to bring this torque in earlier?
Old Feb 11, 2007 | 12:51 AM
  #43
maximagician's Avatar
ms.zilves..didnt you have the low power problem a while back?
i had it but am currently(for now) bypassing knock sensor with the resistor
what was wrong with yours?
Old Feb 11, 2007 | 08:01 AM
  #44
94 max's Avatar
funny thing is you can wrap your stock exhaust to increase exhaust speed due to heat staying in the pipe thus make the gases move faster thus increase efficiently thus increase horsepower
Old Feb 11, 2007 | 08:44 AM
  #45
Alex_V
Also rusting it faster. Best thing is to get a performance exhaust and get it coated with a thermal barrier. Lots of company's do it now.
~Alex
Old Feb 11, 2007 | 11:30 AM
  #46
mszilves's Avatar
Yes, it was definitely worse in the summer with a heat soaked engine...
I found it to be my knock sensor, and I'm also doing the resistor bypass for the time being. Since I run only 91+ octane, I haven't had any problems. I've been putting off replacing it since it's a major PITA.
Old Feb 12, 2007 | 02:17 PM
  #47
Originally Posted by mszilves
my knock sensor,I'm doing the resistor bypass for the time being. Since I run only 91+ octane, I haven't had any problems. I've been putting off replacing it since it's a major PITA.
and its exspensive. im wondering how my\our cars will run in the hot weather
since before i did the bypass it really only went low power in the summer heat
so you think heat messes up the old\worn knock sensors or creates more knocking? i have to remember the k.s. isnt a knock PREVENTER it only "hears'
knock and retards engine to "prevent"damage not totally eliminate it
i dont hear any obvious knock only lite tapping RARELY when hard accelerating (sounds similar to my vtcs)which i only hear a little when cold
im also using 92 octane has anyone ever had knock related damage on ve or vg engines...that they were sure about(not scammer mech. diagnosis)?
anyone think knock sensors are a luxury item to keep the motor quiet?
Old Feb 21, 2007 | 04:30 PM
  #48
dking21's Avatar
I talked to Dallas at Warspeed. He said that if you have a Sohc that the 2.5" y-pipe and cat are fine. But from that cat back he would not recommend going any bigger that 2.25".
Old Feb 21, 2007 | 05:18 PM
  #49
goon9's Avatar
If you want to bottle neck your exhuast, have fun
Old Feb 21, 2007 | 07:53 PM
  #50
CapedCadaver's Avatar
Call me Wookiee Goldberg
Originally Posted by SeaMAX
I had the same problem. I had 2.25 piping with a 2.5 cat with dual exhaust setup
Duals on a 3rd Gen? Do you have pics of that? I've been wondering about how it would look having duals on a 3rd gen; it'd take some playing with the distance between them to get the right look (as well as possibly mounting them higher and cutting into the rear bumper like a 2000-2004 Mustang GT does)
Old Feb 21, 2007 | 08:12 PM
  #51
Mizeree_X's Avatar
Getting back to his roots
When I switched from a hi-flow cat back to stock, my low-end improved.
Old Feb 21, 2007 | 08:14 PM
  #52
goon9's Avatar
http://forums.maxima.org/showthread.php?t=445808&page=2
http://forums.maxima.org/showthread....58751&t=438744
Note on the last link, I had a new pipe pipe bent from the cat to the muffler. I threw that together long ago just to drive it around. Still need to redo the rear end to make the tips look right.
lowpost99
Oct 26, 2025 06:53 PM
The Frye
Sep 2, 2021 11:03 AM
TheMafia
Sep 4, 2015 08:26 AM
Justin Kroll
Sep 2, 2015 11:06 AM
A32goldylocks
Sep 2, 2015 06:39 AM
