A/T Mistery, Please Help me!
Old Dec 15, 2006 | 08:55 AM
tobinaz's Avatar
Yesterday while driving my 94 noticed that the car didn't move when I pushed the accelerator has if it were in neutral, moved the stick to first and moved after a few seconds. Unfortunally it happened again and again till I had to drive a few miles to get to destination in what appeared was driving in third or fourth.
After aproximately an hour I drove it home to at least park the car indefinetly thinking the transmission broke and the car drove kind of normal, thinking that I won't be able to afford a transmission fix or replace.
Today I had drove it for 5 miles to work and looks worked normal.
Some of the things I have noticed is that the selector for Comfort or the other type of driving sometimes didn't light till it didn't light at all for a while, then when cold the shift from 1 to 2 is rough (it kind of jumps or takes to many rpms). I have changed transmission oil a couple of times since when I bought it with 97Kmiles looked like it was never changed, found a little metalic debri the first time, none the second.
PLEASE HELP!
Old Dec 15, 2006 | 09:48 AM
Greeny's Avatar
¯\(°_o)/¯
Sounds like you're going to the tranny shop for a rebuild..
Old Dec 15, 2006 | 10:11 AM
Jeff92se's Avatar
I'm needing a caw
AT shift selector bushings or contacts are old/bad
Old Dec 15, 2006 | 10:19 AM
Greeny's Avatar
¯\(°_o)/¯
Meh,the rough shifting between 1st-n-2nd gear he speaks of sounds like a slowly dying tranny to me..
I doubt the comfort/power switch would cause this issue..
Old Dec 15, 2006 | 10:47 AM
tobinaz's Avatar
WHERE ARE THIS LOCATED?
CAN THEYE BE REPLACED?
Old Dec 15, 2006 | 11:00 AM
nc90gxe's Avatar
tobinaz
i hope u dont need a rebuild but just in case
same thing happened to me for a few weeks then the trans died only 1st and 2nd worked. got it rebuilt for about 1000. after your rebuild make sure u leave it in power mode, the trans company told me comfort lets it slip too much destroying the tranny.
Old Dec 15, 2006 | 11:38 AM
Jbr8k's Avatar
http://www.cardomain.com/ride/748507/15
It wouldn't hurt to clean your tranny's electrical connections in the engine bay and also the tcu plugs .
Old Dec 15, 2006 | 12:28 PM
tobinaz's Avatar
great information, thanks alot!
Old Dec 18, 2006 | 09:06 AM
tobinaz's Avatar
Transmission Was Fine. It Did Resent After Turn On Engine. It Has A Safety Switch That Puts Transmission In Third. Thanks To The People Who Reply To My Message And Hope This Works For Someone Else
09maxshawn11
Aug 9, 2015 01:13 PM
Nore474
Dec 23, 2002 08:43 AM
torontoboy
Nov 15, 2002 07:23 PM
gottriceguy
Oct 15, 2002 11:14 AM
max808
Jan 25, 2002 01:42 PM
