Cooling problem, 92 GXE
Old Mar 8, 2007 | 07:20 AM
cardana24's Avatar
Blown
My brother has a 92 GXE. A few nights ago he did not make it back home because the car got hot and the upper radiator hose blew off and he lost all of his coolant. So my dad asked me to put a thermostat in the car. I did that and blead the coolant system. The car had heat again and ran fine for half an hour, so we thought the problem was fixed. Well we were wrong, my brother called again last night saying that the upper radiator hose blew off again. What in the world is causing this? One thing that I noticed is that when I was filling the coolant system back up, the heat started working again but the lower radiator hose never got warm even after running the car for half an hour. The temp gauge stayed in the middle between H and C the whole time. What could cause this? Thanks for any help.
Old Mar 8, 2007 | 07:43 AM
maxitech's Avatar
First off, make sure the hose is tightly secured with the clamp (not too hard or you might crush the radiator inlet.) Also, you need to fill the coolant with the car at (or as close to as possible) a 45 degree angle. (Try to find a steep hill to park on.) After doing that, there is a coolant bleeder screw sitting on top of the engine. Open that while the car is running do get out any air bubbles remaining in the system. Good luck!
Old Mar 8, 2007 | 07:45 AM
Greeny's Avatar
¯\(°_o)/¯
How did you bleed the air out?
The best way is to jack the front end up as high as possible [2-3ft],run the engine for 10-20 minutes while constantly topping off the radiator until it is full,make sure the car warms completely up through the process..
Old Mar 8, 2007 | 08:23 AM
cardana24's Avatar
Blown
I think I filled the coolant correctly....or at least according to the Haynes manual. The car was pointing up hill on ramps, so it was pretty close to a 45 degree angle. I opened the air bleeder that is right behind the IM. I left this open until coolant ran out of the bleeder, and then closed the bleeder. Once I did this I left the radiator cap off and cranked the car, the was squeezing the upper and lower radiator hoses trying to "burp" air out of the system. Once the heat started working again I put the raditor cap on and topped of the resivor. I thought I did it right but feel free to let me know if I missed something. Does it sound like something is clogged? Why would the lower radiator hose not get warm? Thanks for any help.
Old Mar 8, 2007 | 08:32 AM
redwood_usa's Avatar
You probably have debris in your cooling system that is causing your thermostat to stick open.
Remove thermostat, replace housing, disconnect top radiator hose at the radiator, flush with garden hose through the radiator cap. Then drain, refill with NEW coolant.
Old Mar 8, 2007 | 08:37 AM
cardana24's Avatar
Blown
that does not make since to me since the car is getting hot a blowing the upper hose off. If the thermstat was stuck open then wouldn't the car run cool?
Old Mar 8, 2007 | 09:07 AM
crabapple's Avatar
Is it getting hot thus blowing the upper hose off or is the upper hose blowing off thus getting the car hot?
I am sure you have checked this but I had that hose replaced and about a week later I overheated on the highway. I shut the car off and was actually able to coast all the way to a gas station right off the exit ramp (total luck that I was not stopped by a light or another car). When I opened the hood the hose was off because that piece that it connects to on the radiator itself was broken. Had to get a whole new radiator.
Old Mar 8, 2007 | 10:09 AM
cardana24's Avatar
Blown
I am not positive, since it is not my car and I have not had a chance to ask my brother. I just assumed that it was getting hot and blowing the hose off. Can any one tell me why the lower radiator hose is not getting warm?
Old Mar 8, 2007 | 10:21 AM
Alex_V
Its suppose to be cool/cold, as a radiator does cool the coolant off. I was driving around for a while I'll check and see if mine is cold or warm when I go back out side.
~Alex
Old Mar 8, 2007 | 11:11 AM
Ok - lets try this again. When you say the hose blew off, did it burst or did it come off the clamps (old and new) ?? If it came off the clamps you have a clamping problem. How cold is it where you are. If its really cold you can expect the lower hose to stay warm to cool as the radiator is cooling off the coolant efficiently. Especially if the thermostat is stuck slightly open. When I had a stuck open thermo the lower hose never heated up.
Old Mar 8, 2007 | 11:19 AM
cardana24's Avatar
Blown
Ok - lets try this again. When you say the hose blew off, did it burst or did it come off the clamps (old and new) ?? If it came off the clamps you have a clamping problem. How cold is it where you are. If its really cold you an expect the lower hose to say warm to cool as the radiator is cooling off the coolant efficiently. Especially if the thermostat is stuck slightly open. When I had a stuck open thermo the lower hose never heated up.
The hose did not burst. That's about all I know, I have not talked to my brother, and he has only told my dad very little. At night the temp's here have been in the upper 20's. I'll try to get more information from my brother tonight, but he does not know much about cars and he is not very observant so I don't know how much more information I will be able to get. The water temp is still showing to be in the middle of H and C, if the thermostat was stuck open wouldn't it show to be cooler than that?
Old Mar 8, 2007 | 11:42 AM
crabapple's Avatar
Who put the hose back on after it "blew" off?
When you refilled the coolant and put in the thermostat was the hose already back on?
If he put it back on and you have not checked that piece of the radiator that the hose clamps on to, I'd bet $100 - well, make that $25 - that it's broken and there's not a good connection between the hose and the radiator. The hose is coming off, the coolant is draining out and that's why it's overheating.
The guy who put in my radiator said they see that all the time when replacing radiator hoses on high mileage cars.
Old Mar 8, 2007 | 12:30 PM
cardana24's Avatar
Blown
My brother put it back on, I am making the assumption that he put it back on tight. You are making a good point. I just need to get some time to actually look at the car. My problem is that my brother is helpless when it comes to automotive stuff, and I work all day and he works nights.
Old Mar 8, 2007 | 01:08 PM
92 Max's Avatar
Also, Run the car with the radiator cap off just to look for air bubbles in the coolant. Perhaps he has a head gasket problem. Be careful of the hot coolant and, if it does bubble, the hot coolant may burp out, so don't stand right over it.
I'm not talking here about gas pockets in the coolant system. I'm talking about a blown head gasket or such pressurizing the coolant system. These bubbles won't go away.
Old Mar 8, 2007 | 03:25 PM
Greeny's Avatar
¯\(°_o)/¯
If you don't do it the way i explained,you will NOT get all the air out of the system..
Old Mar 8, 2007 | 06:30 PM
bvtran's Avatar
94c Big Max
urgh, I think I know the problem your having. How did you filled in your coolant? The right way is first, fill the radiator. Shut the cap. Fill the reservoir. Run the engine. After 5-10mins, the system will suck in the reservoir. If its emptied then hot air will build up in place of coolant and it will cause the hoses to implode. You could see this from happening as it the hoses contract. So what you need to do is pay attention, as soon as it sucked from the reservoir. Let it emptied it out first. Then keep refilling it until it longer emptying out the reservoir. This process takes about 30mins.
Don't do it on a ramp when your filling an empty system because if your on a ramp and that rad cap is opened then the system will not build up enough vacuum to distribute the coolant evenly. The only time that ramp is useful is for bleeding and topping but not for filling from an empty state.
Old Mar 8, 2007 | 06:50 PM
LvR's Avatar
LvR
The right way is first, fill the radiator. Shut the cap. Fill the reservoir. Run the engine. After 5-10mins, the system will suck in the reservoir. If its emptied then the hoses will implode. So what you need to do is pay attention, as soon as it sucked from the reservoir. Let it emptied it out first. Then keep refilling it until it longer emptying out the reservoir. This process takes about 30mins.
I don't know on which planet you circle Uranus, but here on Earth, that is the wrong way to fill the cooling system .............. in fact its one way to guarantee not to do the job properly.
There is simply no way the cooling system will suck anything from the reservoir while following your recipe.
The reservoir is there to catch the overflow from the pressurized HOT cooling system due to expansion - hence its also known as a an expansion tank. When the cooling system eventually cools down after the engine is switched off, the coolant inside the engine contracts, and if your radiator cap is working the way its supposed to, will allow water to be sucked back into the cooling system from the expansion tank - ie keeping the cooling system always full of liquid.
If you have air in your cooling system because you have not followed the correct radiator filling and bleeding procedure (see earlier posts), there will be no or very little "sucking" action when the system cools down and hence no automatic replenishing from the expansion tank - cooling and contracting water is the thing causing the expansion tank's ability to keep the system full - you need a properly filled cooling system to start with else the expansion tank may as well not be there
Old Mar 8, 2007 | 07:01 PM
bvtran's Avatar
94c Big Max
LOL
The reservoir is for overflow but its also act as an emergency refill if the system ran empty. The way the system circulate coolant from the engine block to the radiator was by vacuum. You need that radiator cap closed so vacuum pressure could build up and if that cap was closed then the only way to keep refilling from an empty state is thru the reservoir. I've been doing this all the time and I had nothing but successes.
Old Mar 8, 2007 | 07:13 PM
LvR's Avatar
LvR
Originally Posted by bvtran
LOL
My learned friend, here is a life lesson for you ........... use it well and often.
Old Mar 8, 2007 | 07:14 PM
bvtran's Avatar
94c Big Max
are you Wiking's evil twin brother?
Read the whole thread, he obvious has tried your method and it didn't worked. He even went as far as changing the thermostat, bled it on a ramp, and nothing worked. What more can you say about your method? Quit being delusional.
Old Mar 8, 2007 | 07:19 PM
LvR's Avatar
LvR
No, but I taught them both a few things.
Fact remains - if you dont know what you are talking about, its often best to not start an argument.
Old Mar 8, 2007 | 07:23 PM
bvtran's Avatar
94c Big Max
LOL
am I starting an argument or you did? what's the matter, is it too cold outside? *sigh* that delusional feeling must be a result of frozen brain.
Old Mar 8, 2007 | 07:33 PM
LvR's Avatar
LvR
LOL
My friend, there is absolutely nothing wrong with posting an alternative approach to an unsolved problem experienced by your piers ......................... but for crying in a bucket, make it sensible and not just a "post in a thread ".
Your understanding, explanations and motivations so far has absolutely no basis in reality - its really as simple as that.
Enjoy crapping on me and defending the right to post total garbage - its a privilege the Internet afford you.
Old Mar 8, 2007 | 07:52 PM
bvtran's Avatar
94c Big Max
Ok, this is going to be last time I reply back to you. The only reason I viced my method was because I had this problem before. I have done this 3 times already so I know the solution to the problem he might be having. If you don't like what I post then chill out. Stop being a smart azz. You have no right to tell people what to post because any solution is better than none. And your certainly not helping either. Right now he's a in a thread lock and he needs a solution fast.
Old Mar 8, 2007 | 08:31 PM
Greeny's Avatar
¯\(°_o)/¯
bvtran,you need to settle down dude...you seem to think you are some kind of maxima wizard here lately...umm you're not...LVR has more maxima/car knowledge in his left nut than you have in your whole body...so chill dude..
Old Mar 8, 2007 | 08:55 PM
CapedCadaver's Avatar
Call me Wookiee Goldberg
what drama in this thread! If only they made a pressurized cooling-system-filler, that did all the work for you, flawless every time. Like, something that could fill from the bottom to the top, instead of the top to the bottom.
The only cooling system junk i've come across is in a camry, where the expansion resevoir has a hose dropping down into the resevoir from the resevoir cap, instead of having a non-hosed cap, and a hose at the bottom of the tank. Well, his little diphose fell into the tank, and he didn't know it, and in conjunction with his cracked upper radiator hose, he was losing coolant, adding when it cooled down, pushing it into the expansion resevoir when he overheated, and never sucking it back in when it all cooled down. That's what he gets for neglecting his battery, which exploded and shot acid all over the place, and ate a hole in his radiator hose. If acid doesn't affect rubber, then ignore the preceding sentence.
Old Mar 8, 2007 | 09:48 PM
LvR's Avatar
LvR
capedcadaver
I like the way Volkswagen designed their systems - the pressure cap sits on the expansion tank with a completely sealed radiator, and the expansion tank basically feeds both the radiator and the engine just before the water-pump ..................... that is in addition to a constant recirculation from the engine's hot side and the top of the radiator to the expansion tank too - all of that while the bottom of the expansion tank is higher than both the engine's cold feed and the top of the radiator, so there is no bleeding required - just keep the expansion tank level where it should be and you are set ............... I think that is about as close to optimum you can realistically get on a car
Old Mar 9, 2007 | 04:01 AM
jackb_guppy's Avatar
thermostat!
thermostat!
thermostat!
thermostat!
I had the top hose blow off too. The thermostat froze close.
Old Mar 9, 2007 | 05:31 AM
Alex_V
+1
My 240sx had an air pocket, and I over filled the over flow tank and tried to go home (2am in freezing chicago). Well it over heated.
The only time it will pull water into the radiator is when the car cools off. Not turns off but the cooling system gets down to ambient temperature.
If ramps don't work then jack up the front end until the rear bumper hits the ground....I didn't and I still have a air pocket or two.
~Alex
Old Mar 9, 2007 | 06:38 AM
cardana24's Avatar
Blown
I am pretty sure we are on the same page with that. I used ramps instead of a jack, but the same thing was accomplished.
I should have a chance to talk to my brother this weekend and look at the car some more. It seems to me though, if I did not bleed the cooling system correctly then the heat would not have worked and the temp would not have stabalized in the middle of H and C IMO.
Old Mar 9, 2007 | 06:55 AM
Greeny's Avatar
¯\(°_o)/¯
It all depends on where the pockets of air are located in the system,i helped a local orger a few years ago with the same issue,he didn't have a jack that would raise the car high enough to get all the air out of the system,then i brought my larger jack to his house,jacked the car about 3ft in the air[jacked it up/put the car on stands/then put my jack on cinder blocks to add some more height] bled the system again..He had no more problems after that...
Old Mar 9, 2007 | 07:10 AM
If you cant find a good enough ramp or jack , find a nice hill in your area that meets the angle. lot easier with all four wheels on the ground.
Old Mar 9, 2007 | 07:50 AM
LvR's Avatar
LvR
seems to me though, if I did not bleed the cooling system correctly then the heat would not have worked and the temp would not have stabilized in the middle of C and H.
Air in a liquid based cooling design is bad news - no matter how you look at it.
Liquid based cooling systems rely on the fact that the liquid in contact with the metal will remove the heat, and as the temp increase, the pressure on the liquid is increased in the confined space of the sealed cooling system, preventing the liquid from boiling (up to around 105C I would guess with a .9 bar rad-cap) - because once the liquid starts boiling, you have bubbles in contact with the metal surfaces iso liquid only, and we all know liquid (water and glycol in this case) is a much better heat transfer agent than air (bubbles)
With air in the system, you are effectively lowering the design boiling point (Temp) of the liquid in the cooling system because the air in the system can be easily compressed unlike the cooling liquid, and the liquid therefore reach boiling point at a lower temp, effectively instantly flashing the liquid to steam soon as it touches the overheating metal .......... causing even further temp rise in the metal because of even poorer heat removal etc etc etc in a very quick and viscous circle.
My guess is the Max's cooling system is luckily, by design, sized in such a way that it may be able to tolerate quite a lot of "abuse" - ie - it will keep cooling the motor even with some air pockets in the cooling system, until the liquid starts boiling with the temp still indicated being "normal", and the "heat" working because there is some hot liquid circulating after-all (I am assuming that there is only small air pockets in the system and its not half filled with air). At this point where the liquid starts boiling due to air pockets, a situation will quickly be reached where, if you continue to add heat (by driving), the metal surfaces are so hot that all the liquid starts flashing to steam soon as it gets in contact with it, and in a very sort time, you will have mostly steam in the cooling system, while the steam pressure is building at a very rapid rate approaching the cap's release pressure. If you are not quite expecting and intent on detecting this situation, you may very well miss the quick temp rise showing the impending disaster.
In your case the question must surely be why the radiator cap didn't relieve the pressure and allowed the radiator hose to be blown off - that is after-all exactly what part of its purpose is.
My guess would be a combination of possible air in the system and a bad rad cap (assuming the rad-hose was properly fitted to start with) .................. or then a real simple rad-cap failure to open at the correct pressure with even a properly filled cooling system .................... me? - I would definitely start by replacing the rad-cap
Sorry for all the long technical stuff but you did pose the question.
Edit: Fixed many spelling errors
Old Mar 10, 2007 | 06:40 PM
internetautomar's Avatar
mod or sell?
They do make such a tool.
Old Mar 10, 2007 | 06:47 PM
alrighty then. Luckily i haven't had cooling problems, so I guess I'll figure these things out (ie reading posts/fsm) when i get to that point in the car's life. Now that I know a 5-speed swap is possible, I'm probably going to do that, and run her until she lays down. So eventually I'll get to run into some problems.
Old Mar 12, 2007 | 05:38 AM
cardana24's Avatar
Blown
I had my dad put a new clamp on the upper hose and it seems like everything is fine. I guess I should have checked some of this stuff myself before I changed the T-stat, but my dad asked me if I could change the t-stat...so I did. After talking to my brother, he told me he was able to just stick the upper hose back on when it blew off, he did not have a screw driver or anything to tighten the clamp...he just pushed it back on. Hopefully that is all the problem was. Thanks for the suggestions everyone.
pears
Sep 18, 2015 05:25 AM
rnb754
Sep 14, 2015 11:39 PM
Maxima Pride '07
Sep 12, 2015 07:29 AM
