Is my Chiltons wrong and ColumbianMax right?
Old Apr 7, 2007 | 06:26 PM
JRS89MAX's Avatar
Went through search to check on Timing.Which for my 89 GXE should be 15.
Now in the Chiltons Chapter 2 -13 it has it as the 3rd line .It goes.
l l l l
0 10 15 20
Clombianmax Has it the 4th line
(firewall) | | | | | | | (headlamp)
...................15
Cause I just changed my timing and went by the CHILTON cause I changed the valve cover gasket and moved the distributor.So do I have it on 10 or 15 right now?
Old Apr 7, 2007 | 06:33 PM
CapedCadaver's Avatar
Call me Wookiee Goldberg
l l l l
0 10 20
from the FSM
Old Apr 7, 2007 | 06:55 PM
JRS89MAX's Avatar
In his video he says 0 ,5 ,10, 15
Old Apr 7, 2007 | 07:12 PM
yeah that's what that picture shows too. it starts at 0 (first mark) and counts by 5* so it's 0* (1st), 5* (2nd) 10* (3rd) and 15* (4th)
Old Apr 7, 2007 | 07:27 PM
JRS89MAX's Avatar
Unless you have to count the line on the point.Cause it shows the point which has a line on the center of it. Then it goes 0,10,15,20.
ColumbianMax has it the 4th line.
So where should i have it on 3rd or 4th line?
Because right now i have it on the 3rd line. Is that 10 or 15 ?
Old Apr 7, 2007 | 07:37 PM
the thing labelled "timing indicator" is covering up the 15* line, but the line is still there, and it's the 4th line. the lines are evenly spaced and do not skip. they are 0, 5, 10, 15, 20, 25, 30. you want the one in the very middle, for 15* timing.
time to the 4th one. or if you use higher octane gas, between the 4th and 5th (around, say, 18*, that's what mine runs)
Old Apr 7, 2007 | 07:45 PM
JRS89MAX's Avatar
Ok. So the timing indicator in the picture is covering a line up? So tommorrow when I do my timing i'll put it on the 4th line? Correct?
I just freakin noticed. On the pic towards the lower right where it says
B.T.D.C. Mines is faded. Its the freakin 4th line.
Old Apr 8, 2007 | 04:39 AM
ColombianMax's Avatar
Hey I just noticed my name was mentioned lol...
the 4th line should be 15 degrees according to what I read on FSM. Like Capedcadaver said if you want a bit of advanced timing, simply put it between the 4th and 5th line and thats about 17-18 degrees, you'll feel a nice difference but be sure to use 92-93 octane aka Premium
btw not to be a **** but its Colombian with an O
oh and your chiltons is a POS, I hate Chiltons and Haynes, they cant even get their generations straight
Old Apr 8, 2007 | 07:52 AM
JRS89MAX's Avatar
Sorry for the misspelling. My deepest apoligies.Changed it this morning to 4th line.
Old Apr 8, 2007 | 11:52 AM
Did you make sure you car was on Neutral when you adjusted the timing? oh by the way how does it feel now?
its cool about the spelling, its a VERY common way to mispell it, especially in America
Old Apr 8, 2007 | 05:47 PM
It depends if you're from Colombia the country (yes i even know the capital is Bogotá). yay for random knowledge) or Columbia SC. Or Columbus OH.
Anyhow, the Hayne's stucks because it goes 85-92 then 93-04. What kind of crap is that? They took an 86 and a 95 and called it a manual? They should have had the brains to separate them by generation truly, plus they have no book with a 3rd gen teardown. Succccks.
Old Apr 8, 2007 | 07:24 PM
GRNMAXDMON's Avatar
crap i never noticed this when i did my timing belt. i just went by the timing marks in my FSM. then again you guys are talking about the distributor being moved when the front valve cover gasket needs replacement and i did the same thing. and for a moment i got lost cuz i didn't mark the position in which i pulled out the distributor. luckily Matt was there to help and so was my old boss from the shop that i use to work at. but i never noticed at what degree mine stayed at. mind you that i swapped my engine in after that little confusion and it has been running nice since then but i will take a look at this to see if mine is where it should be.
Old Apr 8, 2007 | 10:25 PM
mtcookson's Avatar
You should check out the Chilton's manual for the early Z cars... covers 1970 up to 1988, so... the 240Z, 260Z, 280Z, 280ZX n/a and turbo, and the 300ZX n/a and turbo. On top of that they can't even do vacuum diagrams right (among many, many, many other things). They had wiring mixed in with the vacuum diagram that had nothing to do with anything. Complete idiots.
Old Apr 9, 2007 | 12:31 AM
Originally Posted by mtcookson
.....Complete idiots.
I couldn't have said it better
Old Apr 9, 2007 | 08:05 AM
Matt93SE's Avatar
STFU n00b!
If you're using a stock pulley, aim for the yellow timing mark.
Old Apr 9, 2007 | 08:47 PM
JRS89MAX's Avatar
Yeah I had it in neutral. It feels a lil better.Gonna check the gapping on my plugs tommorrow. Gonna do a throttle body cleaning. Have a minor studder that I cant figure out.
Old Apr 10, 2007 | 12:38 AM
Yea lil stuff like that makes a difference!
I just got myself some 8.5mm plug wires like Alex Vs and nForces and they're nice, not bad for 56 bucks
Old Apr 10, 2007 | 05:47 PM
nForce's Avatar
The Computer Guy
oh now you have those wires too... Ha I got them and alex didnt really believe they worked till he drove my maxima. but yea those wires kick a"s"s what color did you get? Red?
Old Apr 10, 2007 | 09:08 PM
JRS89MAX's Avatar
Well check the plugs. One was like 50 something. Feels a lil better .Trying to get the throttle body gasket. Nobody has them all special order.Rides great.Just when im at a stop that sputter that i once in a while get thats so annoying.
Old Apr 10, 2007 | 09:10 PM
the TB gasket is usually always in stock at the dealer and is usually just 2-4 bucks more expensive than at the average parts store, I'd check your local dealer, hell I've actually seen OEM parts cheaper than cheap aftermarket at Autozone
Old Apr 11, 2007 | 11:40 AM
Jon94SE's Avatar
God I hate Chilton's. I'll take a Hayne's book over Chilton's anytime.
Old Apr 11, 2007 | 04:41 PM
but believe it or not, I've spotted several typos and wrong info in the FSM too... especially concerning parts-testing procedures
Old Apr 12, 2007 | 07:46 PM
JRS89MAX's Avatar
Well I beleive after the regapping and lowering the idle helped alot.Rpm needle not jumpy.Still gonna do the throttle body cleaning this weekend.Also switched to 89 oct.
Old Apr 12, 2007 | 08:03 PM
http://btp.mine.nu/Jared/max.org_stu...s/MVI_2130.avi
^^did it used to be like that?^^
Old Apr 13, 2007 | 04:57 PM
Darkwing48's Avatar
Here's an idea?
Why not publish a 3rd gen manual?
We got stickers, a website, knowledge (well, some of us)
We need it!!!!!!!!!!!
All current manuals suck
Old Apr 13, 2007 | 05:10 PM
a-effing-men
who's up to the task?
Old Apr 14, 2007 | 01:49 PM
JRS89MAX's Avatar
Couldnt see the video. But before i changed the injectors and moved the distributor which put it out of timing it wasnt jumpy.
Today I cleaned the Maf sensor with Maf cleaner.
Cleaned the throttle body. Was pretty bad. Pedal not sticking no more.New gasket.
Redid the idle Ecu clockwise and car in neutral.
Checked the PVC valve which is kinda new.Found a small piece of gunk In it.
Cleaned it up.
Engine pretty quiet and RPM needle steady.
Old Apr 14, 2007 | 06:49 PM
internetautomar's Avatar
mod or sell?
FSM works fine for me.
I've had mine since shortly after I bought my first VE.
Forge277
Jun 13, 2016 09:26 PM
BobTX10
Oct 7, 2015 08:43 AM
bigfrank
Oct 1, 2015 12:51 PM
pears
Sep 18, 2015 05:25 AM
