Front Suspension For My 94 Gxe
Old May 26, 2007 | 06:55 PM
RayRey21's Avatar
ok...the suspension is original equipment and feels like a caddy and I hate it.....looking for a stiffer ride an......what do you guys recommend for a front suspension on my GXE.....SE struts??? GXE struts??? Need your opinion on this one....almost bought an SE Max bought the douche bag didn't want to sell it......your opinions are deeply appreciated!
thanks
Ray
Old May 26, 2007 | 06:59 PM
Quickywd01's Avatar
The se maxima had a tighter suspension and thicker sway bars. If you are looking for more of a performance ride changing the struts, springs, sway bars, and adding strut bars will help. Don't forget the performance tires.
Old May 26, 2007 | 07:09 PM
RayRey21's Avatar
should I change the struts, sway bar, springs to an SE setup???? if so, I will order it................FSTB will be added..but what about the rest???
thanks dude
Old May 26, 2007 | 07:41 PM
CapedCadaver's Avatar
Call me Wookiee Goldberg
thanks dude
well lots of people on here go with aftermarket struts. Konis are the favorite. KYB GR-2 and Tokico are the other two preferred brands. You can get some SE springs and swaybar, but I think you'd be better off buying Konis, according to 90% of the members on here. They have adjustable stiffness settings IIRC. And if you want to lower your ride, you can get drop springs that will still be tastefully stiff while giving your Max a more agressive stance as well. Stock SE components will be good, but I believe that you'll probably be more satisfied with some aftermarket struts and (optoinally) springs.
Old May 26, 2007 | 10:47 PM
DennisMik's Avatar
If the suspension is ALL original, then your struts are well past replacement time. if your not trying to do performance driving, the strut replacement will be your answer. i used KYB (front and rear) and thought I had a new car.
Old May 27, 2007 | 06:39 AM
RayRey21's Avatar
the next obvious question is where can I get the Konis???? cheap!....I want to make the car run good but not looking to drop toooo much loot in the car....
I will start to look around myself but do you guys recommend anyplace to get them?!
thanks again fellas
Old May 27, 2007 | 06:42 AM
RayRey21's Avatar
one other thing.....my car has the adjustable suspension button on the center counsel.....will that effect which strut I have to buy???
thanks
Old May 27, 2007 | 07:20 AM
Pearl93VE's Avatar
I can has?
thanks
That is an automatic transmission setting, Power and Comfort mode. It adjusts shift points under normal (low to mid throttle) driving situations. You can buy any strut you like as the adjustable suspension will depend on the strut itself, not the car.
Old Jun 4, 2007 | 09:50 AM
bLiNg_ThEoRy's Avatar
I think he's referring to the Nissan Sonar Suspension Damping control switch. It was an option for the SE and is rare.
Old Jun 4, 2007 | 10:01 AM
Pearl93VE's Avatar
I can has?
oh, that may be. But I don't think it was an option in the SE's. I think it was only GXE's.
markevans999
Oct 25, 2015 08:27 AM
GregL65
Sep 5, 2015 09:37 PM
jfl330
Sep 4, 2015 01:44 PM
A32goldylocks
Sep 2, 2015 06:39 AM
