When VTC goes bad....
Old Jun 1, 2007 | 05:09 AM
nicks79's Avatar
I picked up a 93 max SE with VTC gone bad (car stalled in 2nd gear) on previous owner. I picked it up as a donor or to swap my SE engine from Automatick. Car has about 131k miles on it. The links are the pics of what happened to the motor.
http://pg.photos.yahoo.com/ph/nicks7...cd.jpg&.src=ph
On this 3rd photo note the lifters from 2 cylinders are all over the valve area.
What happened was the cup from VTC broke of, jammed the chain, chain slipped off of lower idler sprocket. Then I think timing got off to the point that valvle got jammed by the piston, and distroyed the spark plug. (the spark plug was bent, and ceramic isolator crashed completely). Then lifters on two cylinders fell off. One cracked in half.
I am going to take the head off, just to look at the cylinder, to see what happened. The rear bank should be fine.
My plan is to put my other VE engine into this car, since its 5 SPeed.
Old Jun 1, 2007 | 05:19 AM
Michael's Avatar
Back in a 3rd Gen.
been there done that sold the finished car...twice .
good luck with yours.
Old Jun 1, 2007 | 06:18 AM
Hectic's Avatar
Been there, didn't bother doing that, sold the car as is, still made $500, glad to only have my vg now
Old Jun 1, 2007 | 06:57 AM
Cliff Clavin's Avatar
Way out West
When my car does that, I am going to be so damn mad I will probably light the whole thing on fire.
Old Jun 1, 2007 | 07:22 AM
Hectic's Avatar
Be sure and give me a heads up if you decide to do that
Old Jun 2, 2007 | 05:00 PM
prappl's Avatar
How expensive would it be to pay to have two functional engines swapped (both VEs, maybe between a/t and m/t)? Thinking that might be a way around the inability to find the car I want. Would there be any problems selling the donor car (other than potential buyers being scared off by a car with a non-orig engine)?
Old Sep 4, 2007 | 09:26 AM
braxsusriely's Avatar
VTC disable
Well i've had my car ticking for some time now and with all the stop lights around me it gets kinda (sorry. ) REALLY annoying. So i've read the whole grouding procedure and it seems to work or it only ticks 1/2 the time now. So i just cut the yellow wire completely and only the red is touching the front solenoid. So do i have to cut the yellow wire on both or what?
Thanks!
Old Sep 4, 2007 | 09:32 AM
Greeny's Avatar
¯\(°_o)/¯
Thanks!
You have to ground the yellow wire also..
http://www.geocities.com/craigbrace/
The instructions to this procedure are in the HOW TO section of craig brace's website..
Old Sep 4, 2007 | 09:45 AM
ustfdes's Avatar
- Product of Maxima.org -
dead picture links.
Matt93SE
Apr 8, 2018 09:23 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
bill99gxe
May 28, 2001 04:45 PM
trbo
May 17, 2001 09:25 AM
JonnyMax
Jan 25, 2001 08:58 AM
