Changing the Distributor
Old Jun 22, 2007 | 02:42 PM
jruss1601's Avatar
I was looking to change the distributor on my DOHC motor from another DOHC motor (because the external plastic parts are broke). My brother with some mechanical knowledge says that it may be tricky to do. I honesty haven't looked at it yet so i have no idea if its hard or not but he said to ask you guys if there's any advice or anything i should know before, during, or after i take the distributor out. He doesn't trust Haynes books either.
Old Jun 22, 2007 | 02:46 PM
Greeny's Avatar
¯\(°_o)/¯
Distributor?
The VE30DE is a distributorless engine..
You mean the camshaft position sensor?
Old Jun 22, 2007 | 03:43 PM
Greeny's Avatar
¯\(°_o)/¯
Instructions to removal...
(see pic)Mark or scribe a line on the head/cam sensor on both engines in the same place,so not to alter the ignition timing..Then remove the two retaining bolts on the sensors/swap out/line up marks/tighten down bolts...Done
Old Jun 22, 2007 | 03:54 PM
internetautomar's Avatar
mod or sell?
and exactly how will that help when he is putting in a different unit that will lack the mark :
Old Jun 22, 2007 | 03:56 PM
Greeny's Avatar
¯\(°_o)/¯
Old Jun 22, 2007 | 04:01 PM
mod or sell?
you are ASSuming that either engine has the right timing, and that the sensors will line up identically
I'll stick to a timing light myself.
Old Jun 22, 2007 | 04:09 PM
Greeny's Avatar
¯\(°_o)/¯
Yes i am assuming his timing is correct,and yes i am assuming the timing of the other engine is correct...
How bout you give the guy a chance to respond to my information with any questions regarding the timing of either engine before you start your flame fest...
Old Jun 23, 2007 | 07:40 PM
mod or sell?
no flame fest, just be careful with assumptions. they can easily cause damage. (general speaking, not case specific)
Old Jun 25, 2007 | 11:03 AM
jruss1601's Avatar
What can cause the timing to be off? Engine A was takin from a car that was in an accident that just missed hitting the motor. But it did crack the external plastic piece on this engine (the black roundish piece by the red label on the VE motors "16 valve DOHC") and bend the prongs that plug into a harness. The black roundish piece (camshaft position sensor, i guess) on Engine B was going to replace the one on Engine A. However Engine B was ruined from the VTC breaking. Should i be concerned with something here?
Old Jun 25, 2007 | 11:12 AM
ColombianMax's Avatar
I thought VE was 24 valve..
Old Jun 25, 2007 | 11:32 AM
maxima_man1992's Avatar
The VE is 24 valves
Old Jun 25, 2007 | 11:36 AM
fantastic
Old Jun 26, 2007 | 02:24 PM
braxsusriely's Avatar
even if timing was off.....
on my car i have the cam sensor turned to the left or right is it.... to advance the timing a few more degrees.... just make sure you have a knock sensor light to tell when you go too far :-)
doctorpullit
Mar 29, 2016 11:08 AM
MaxLvr21
Oct 17, 2015 12:11 PM
jds22
Sep 29, 2015 02:03 PM
Noela
Sep 26, 2015 08:22 AM
