brake light
Old Aug 4, 2007 | 09:22 PM
saxytothemaxima's Avatar
brake light
okay. this is so annoying....
[[and also the 4th time]]
my brake light is on and the e-brake is not on. I checked the fluid level and it is fine. The fluid is just below "max" or whatever.
I dunno what could be wrong. Brakes are new.
im hoping the master cylinder isn't pooping on me......
Old Aug 4, 2007 | 09:34 PM
whitemax89's Avatar
Check with the manual what problems does a brake lights stands for.
Old Aug 4, 2007 | 09:49 PM
ColombianMax's Avatar
Its most likely your fluid level even if its just a bit under "max" go to an autoparts store and pick up some Brake Fluid (DOT3), its only about 3 bucks and just fill it up to the max line. Believe me, its happened on most of my friends Nissans
Old Aug 4, 2007 | 10:01 PM
^^^^thanks
Old Aug 4, 2007 | 11:30 PM
elusivemax93's Avatar
it could also be the e brake switch stuck closed on the switch contact making it always say the brake is on when its not. i beleave this has been an isusses before with some of the maximas and there e brake switch.
Old Aug 5, 2007 | 02:26 AM
bla, start with the easiest/most likely cheapest fix and work your way up.
BTW be sure not to spill or drip any brake fluid on your paint as it will damage your paint.
Old Aug 5, 2007 | 09:50 AM
Black92GXE's Avatar
Boomer Sooner
that stuff can be harsh on paint... and definately try the easy fix first..
Old Aug 5, 2007 | 10:07 AM
easy way to clean that up is spraying brake clean on any places he by chances spills on. and also trust me i highly doubt its the just alil below max level of brake fluid as mine is way beneath that and still doesnt come on and stay on it just flickers and also i have brake fluid i just got yesterday to fill it back up.
Old Aug 5, 2007 | 10:06 PM
Carb cleaner/brake parts cleaner is abrasive enough to ruin paint as well. If it doesnt remove the paint, it will at least remove the wax/gloss.
Lets see what input we get after she tops off the fluid in there. If your brake light aint coming on and its way below hers then I suggest you take a closer look at it cuz mine and the g/fs will go off as soon as it's slightly below max, eh could be ours thats messed up, what do I know..
Old Aug 5, 2007 | 11:03 PM
see i have a SE and you have a GXE two different motors and who knows maybe the brake system from yours to mine operates alil different highly doubtful but how knows all i have ever owned are VE's
Old Aug 6, 2007 | 06:04 PM
My g/f has an SE, I have a GXE. Yea I guess we both have VG's
Old Aug 7, 2007 | 07:06 PM
yeahh. i filled it all the way to the max line. The lights off.
I did notice some sludge below the brake booster though. I think its leeking. anyway to fix this? Or ideas?
Old Aug 7, 2007 | 07:12 PM
internetautomar's Avatar
mod or sell?
if you see sludge on the booster, you better pull the master and make sure it isn't leaking. If it is leaking it will destroy your booster.
Old Aug 7, 2007 | 10:43 PM
you can try tightening the two bolts as a temp fix..so I'd probably suggest cleaning it up completely and re-tighten the nuts...see if it gets dirty again. If not then you might need a master cylinder which usually runs about 60 bucks at autoblown or 200ish at the stealership
Old Aug 8, 2007 | 01:54 PM
thankyou! Im about to work on it. :]
Old Aug 10, 2007 | 07:05 PM
well so far theres not a single bit of sludge on there. When I cleaned it though the booster was rustyish and metal around the bolts. ill load a pic tommorow.
Old Aug 10, 2007 | 07:06 PM
mine's the same way...well not mine but the g.fs and yes thats because of the previous leaking master cylinder
mvm062
Nov 30, 2020 09:00 AM
MaxLife17
Jun 27, 2019 01:37 PM
Maxima30
Sep 7, 2015 06:13 PM
A32goldylocks
Sep 2, 2015 06:39 AM
