drivebelt replacement help
Old Oct 22, 2007 | 05:58 PM
Dayle97SE's Avatar
anyone ever replace the drive belt for the alternator themselves? I am considering doing it myself, but what tools would i need? Is it worth it, or should I just have it done.... any advice would help, thanks
Old Oct 22, 2007 | 06:08 PM
Greeny's Avatar
¯\(°_o)/¯
http://www1.autozone.com/images/cds/...3d801f422e.gif
For complete information..Go here--> http://forums.maxima.org/showthread.php?t=296859
Old Oct 22, 2007 | 11:42 PM
ColombianMax's Avatar
Just so you know, you're gonna break a very long 12mm bolt while changing the belt. PB blast and/or heat up before de-tensioning the belt so you dont break the bolt. If you break it then you cant tension the belt which will leave your car squealing like mine did until I vice gripped the bolt out and got a new one from the dealer for 4 bucks.
Old Oct 23, 2007 | 11:50 AM
maxitech's Avatar
Pic of the bolt?
Old Oct 23, 2007 | 12:34 PM
Greeny's Avatar
¯\(°_o)/¯
Originally Posted by maxitech
Pic of the bolt?
Old Oct 23, 2007 | 12:40 PM
gapboi210's Avatar
reminds me i thinks all my belts need replacing. I need to get all the plastic for the bottom too but AI never see them at the JY.
Old Oct 23, 2007 | 02:08 PM
Matt93SE's Avatar
STFU n00b!
generally you won't. they're always destroyed in the wrecks, gone from age, or the JY yanks them off and chunks them when they're pulling the engine out.
If you're lucky, you can find them in the bottom of the trunk where the exhaust, dashboard, and brake rotors usually are.
Old Oct 23, 2007 | 02:58 PM
sublunary's Avatar
you'd be better off buying those off someone on here who is parting out
Old Oct 23, 2007 | 03:11 PM
Greeny's Avatar
¯\(°_o)/¯
It isn't broke yet guys..
Old Oct 23, 2007 | 03:30 PM
gapboi210's Avatar
true i will check the classifieds. when I drive in heavy rain water sprays right on the alternator causing the belt to slip.
Old Oct 23, 2007 | 03:33 PM
Greeny's Avatar
¯\(°_o)/¯
Originally Posted by gapboi210
true i willc ehck the classifieds. when I drive in heavy rain water sprays right on the alternator causing the belt to slip.
You really need to get some side/bottom covers to prevent the belt from slipping.
Old Oct 23, 2007 | 03:34 PM
sublunary's Avatar
actually i was referring to the other guys search for the splash guards not the bolt
Old Oct 23, 2007 | 07:27 PM
I normally roam the JY here often and actually had a hard time finding some splash guards for the undercarriage. I actually managed to get some filthy ones and cleaned the crap out of them. Now they look like new and will be going on this weekend as I have not replaced all 4 mounts.
Ben, as for the bolt's pic, Wayne already posted one except its the other bolt not the one he's got the wrench on.
Old Oct 23, 2007 | 07:34 PM
CapedCadaver's Avatar
Call me Wookiee Goldberg
my bolts didn't break.. rather, the alty just wouldn't freaking budge with both bolts fingerspinningly loose.. I gave up and unbolted the stupid AC compressor one. click. at. a. time.
Old Oct 23, 2007 | 07:44 PM
you got pwned by your ac compressor, click....at...a...time
Old Oct 23, 2007 | 07:52 PM
yeah i was moving the compressor to get to an exhaust stud which i ended up not being able to do anyways... but i wanted to move the alternator to have more swingroom on the socket driver but nOOOOO.
PH98I30
29
Feb 10, 2025 12:03 PM
captchaos
Mar 15, 2016 12:18 PM
dvcamp
Sep 18, 2015 10:17 AM
dcam0326
Sep 8, 2015 11:02 PM
Maxima30
Sep 7, 2015 06:13 PM
