*NOOBIES* The "I am new here,but have a question" thread..(post your questions here)
Old Apr 18, 2008 | 01:32 PM
  #761
CapedCadaver's Avatar
Call me Wookiee Goldberg
Originally Posted by fulyngu
Thanks for the info! I will check it out. Can you swap the electrical connectors on the injectors to see if the power is getting to it?
And for that matter... Where does the power come from for those things? (Can you tell I know very little about cars lol)
heh, nope can't do that. they fire in sequential order. each injector fires at a different time.
Old Apr 18, 2008 | 06:17 PM
  #762
destroy452's Avatar
headlight trouble
Hey everyone. I'm having trouble with my R.H. headlight. It will not work on high beam. The L.H. side will.
Here's what I've done so far:
1) checked voltage- 12V high to ground and 12V low to ground
2) 2 new bulbs. no dice.
3) swapped the working L.H. bulb over- no dice.
I have the FSM, and traced the wiring diagram out. I've got the requiste voltage to the bulb connector, but the bulb will not light up on high beam.
Anyone have any ideas?
Thanks.
Old Apr 18, 2008 | 08:12 PM
  #763
tmolloy's Avatar
Struts and Sway Bar
Hey guys, this is my first time here and my name is Tom. I've been browsing the forums learning as much as I can about the struts. They've been giving me a hard time ever since I got the vehicle (about 3 years ago). I have a '94 Nissan Maxima with 128k miles. The struts would make all kinds of noises, so a friend and I went to Autozone, got the cheap struts (the ones that everyone was complaining about in the 4th gen forums), and installed them. I've had nothing but headaches ever since. I've reinstalled each strut at least once (thank God for lifetime warranty), and have had many, many problems with the struts (continually having to tighten them up, etc.). Whats worse is the noises never really went away.
This is the basic problem: when hitting bumps (slow and highway) it sounds like the struts are rattling back and forth. When I go over speed bumps or the like, I get a very hydraulic sound. I can deal with the hydraulic sound--no biggie, but the constant wobbling sound gets really annoying when going down a bumpy road or cruising on the highway.
I replaced the front passenger strut today and the spring decompressed as I was working on it. Luckily I know enough not to put my face anywhere near the springs, and the strut was laying on the ground (not in the car). So I'm fine and so is my car. Unfortunately, the strut mount crown (top hat, upper strut perch, etc.) is broken, and I have no idea where to find a new one. So that is my first question: Where can I get a new upper strut perch? It's a factory piece of equipment so autozone and the like don't carry it.
My second question is this: What kind of struts would you guys recommend? I don't race, and handling isn't of utmost concern, but I drive approx. 2,000 miles a month, mostly highway, and a quiet, comfortable ride would be nice. It would also be nice to not have to slow to 10 MPH to go over dips, but we can't have it all. I imagine there's not much need to replace the springs as I don't care much about lowering the car. But I would definitely like a nice, quiet ride that is safe and comfortable.
So that's the strut issue. Concerning the sway bar: when I took my car to the mechanic I asked him to look at my strut. They've been degrading like crazy, so I asked him if he would take a quick look to see if there may be any body problems contributing to the excessive wear. He noticed that the C-Clamp (I think that's what it's called) that covers the main bushing on my passenger side isn't even there! I have no idea why not, but I have no clamp actually holding down the bushing or the sway bar. I've looked online, but can't seem to find anything. So this is my third question: Where can I find a c-clamp to hold down the sway bar and bushing? I'd also like to replace the sway bar end links, but all the reading I've done so far on it has been in the 4th gen forum. So, where would I be able to find a sway bar end link/bushings kit for a '94 maxima? I'm pretty confident that I could replace it myself--I just have no idea what I'm looking for.
So those are basically my questions. Thank you for suffering through my long post, and double thank-you for any help you can provide. Thanks guys!
Old Apr 18, 2008 | 09:04 PM
  #764
BenStoked's Avatar
Jesus was a Zombie.
Thanks.
usually the headlight switch causes problems, due to age and lots of use. replace it, and your problem goes away(usually)
(and is it just me or is it almost always the rh light?)
Old Apr 18, 2008 | 09:09 PM
  #765
BenStoked's Avatar
Jesus was a Zombie.
1.)ebay and courtesy-nissan have em(ebay is cheaper, but...)
2.)for the non-racer, kyb and tokico seem to be the choice(kyb is usually thought of as a stock replacement, but the toks are just a few bucks more)
3.) if the threads are good on the car, the junkyard will have em cheap, if they even charge you for 'em (remember the bolts)
Old Apr 19, 2008 | 01:52 PM
  #766
coolsun's Avatar
ecu problem
ok i have a VE auto and i want to find out the codes on the ecu
is there a special key or screw to turn it? where can i find it?
then i tried turning it with a screwdriver
and i waited and there was no light that came on
i turned both ways and waited no light...and yes the engine was on
idk whats the problem with it
or is it i need a special key?
thanks alot in advance
Old Apr 19, 2008 | 03:02 PM
  #767
so you see a window w/ 2 LEDs inside and a screw with a cellophane cover on it right? and that's what you've been trying to turn? if so then you should be getting lights to blink. yours is not like mine tho, b/c yours is a 2-mode system, mine is a 5-mode system. But the premise is the same.
Old Apr 19, 2008 | 03:09 PM
  #768
BenStoked's Avatar
Jesus was a Zombie.
perhaps it may have been because the engine was running? the engine should be off, but the key in the "run" position.
(and cape, i believe they are "3" mode systems, but its just a minor thing(y))
Old Apr 19, 2008 | 03:36 PM
  #769
o ok. Either way i've only got experience with the 5-mode system, so i don't even know how to pull codes off them thar fancy VEs.
on a 5 mode system tho you can do something for checking your AFR with the car on and switching modes, as well as setting idle.
Old Apr 19, 2008 | 08:42 PM
  #770
coolsun's Avatar
ok i will do it wit the car off now
and then whats the different modes all about
what the modes do?
Old Apr 19, 2008 | 09:00 PM
  #771
what the modes do?
the modes are just what you're doing basically. I dunno what is what on a 2-mode but on the 5-mode it's like this:
  1. normal
  2. rich/lean readout
  3. view codes
  4. erase codes
  5. switch monitoring
Old Apr 19, 2008 | 09:07 PM
  #772
coolsun's Avatar
  1. normal
  3. view codes
  4. erase codes
what is the diagnosis mode on the VE?
how to do it?
its it the same as the VG?
counter clock wise blink then clock wise blink?
Old Apr 20, 2008 | 09:55 AM
  #773
MaxZap's Avatar
Uh wtf? never heard of this.... is it crap?
http://cgi.ebay.com/ebaymotors/Super...3756.m20.l1116
Old Apr 20, 2008 | 10:09 AM
  #774
yeah pretty much
Old Apr 20, 2008 | 11:48 AM
  #775
BruceM99's Avatar
Shaking
My 92 GXE shakes alot when in idle does anyone know what the probblem could be and how to fix it?
Old Apr 20, 2008 | 03:47 PM
  #776
Greeny's Avatar
¯\(°_o)/¯
how to do it?
---->http://forums.maxima.org/showpost.ph...4&postcount=18
Old Apr 20, 2008 | 03:50 PM
  #777
Greeny's Avatar
¯\(°_o)/¯
Originally Posted by BruceM99
My 92 GXE shakes alot when in idle does anyone know what the problem could be and how to fix it?
What have you done in the tune up department? plugs?/wires?/ distributor cap?/rotor button?/etc?
Old Apr 20, 2008 | 04:26 PM
  #778
BruceM99's Avatar
i havent done a thing to it. from the day i bought it its has been shaking more then a normal car
Old Apr 20, 2008 | 04:33 PM
  #779
BenStoked's Avatar
Jesus was a Zombie.
do the normal stuff, as greeny said: plugs, wires, distro-cap and rotor, air filter, oil change(with filter), all vacuum lines.... the list goes on, but these are the "easiest" to do.
Old Apr 20, 2008 | 05:20 PM
  #780
Local361NYC's Avatar
New here
Just bought a 92 gxe. Can anyone here tell me where I can find halos and the grille piece that has no emblem in it?
Old Apr 20, 2008 | 05:56 PM
  #781
nismax1994's Avatar
I don't know about the halos, but you can remove the symbol from your grille from behind. Its held in by tabs, just be careful the tabs are brittle.
Old Apr 20, 2008 | 06:03 PM
  #782
coolsun's Avatar
ok i tried the links the autozone one did not work though
i have the one red led one
ok it flashed 3 times slow and then 4 times fast so is that 34?
Old Apr 20, 2008 | 06:23 PM
  #783
Greeny's Avatar
¯\(°_o)/¯
Yes sir, that be the ve knock sensor code.
Old Apr 20, 2008 | 06:47 PM
  #784
coolsun's Avatar
do you really have to remove the coolant pipe and fuel rails?
to get to it
Old Apr 20, 2008 | 07:00 PM
  #785
Greeny's Avatar
¯\(°_o)/¯
to get to it
Unfortunately, yes, all above must be removed to access the k/s.
Old Apr 20, 2008 | 07:18 PM
  #786
coolsun's Avatar
ok thnaks
Old Apr 20, 2008 | 07:55 PM
  #787
modenaf1's Avatar
Dang! Bummer they don't have one of these threads in the 4th gen forum, but I guess I can ask my question here because it applies to 3rd gen SE's too as they I believe have the same exact knock sensor as the 4th gen VQ30DE.
Anyway, my car needs a new knock sensor, and I have seen quite a few knock sensors on ebay for pretty reasonable price ranges, however there seems to be two different model numbers of knock sensor and both apparently are compatible and OEM for our cars.
I see the OEM A82, or the A100.
The ebay ad for the A100 one claimed that it is an updated sensor from nissan and that dealers charge 170ish or so from it.
I was just wondering, does anyone know the differences between the A82 and the A100?
Old Apr 21, 2008 | 05:56 AM
  #788
Greeny's Avatar
¯\(°_o)/¯
They do have one in the 4th gen forum.---> http://forums.maxima.org/showthread.php?t=389852
Yes, the VE30DE/VQ30DE knock sensor is the same part.
The best place to get a knock sensor--> http://internetautosupply.com/catalog/
Old Apr 21, 2008 | 08:06 AM
  #789
kustomkoncepts's Avatar
Hi I have a 94 maxima and I am trying to figure out how to program the keyless entry number pad on the doors. The dealer ship wants to charge me like $100 and I can't find any info about it anywere. So if anyone can help it would be greatly apprciated.
Old Apr 21, 2008 | 08:39 AM
  #790
Greeny's Avatar
¯\(°_o)/¯
http://www.cardomain.com/ride/454290/7
Welcome to the org.
Old Apr 21, 2008 | 08:42 AM
  #791
there's a box up under the passenger side foot area that has 3 lines of numbers printed on it. one starts with an S, one with an F,, forget the other. anyhow you take (I THINK?!) the bottom number and press CLEAR then enter that number, wait a second, enter the number you want, and it will beep at you. I'm going off memory here so if it's not right i claim ignorance but that should work.
edit: the jolly green giant beat me
Old Apr 21, 2008 | 09:03 AM
  #792
viperbite's Avatar
lol yes he did. and ive got to try that myself with my current issue.
it seems that ive made the security system angry aswell.
basically nothing turns on when i turn the key on. brakes dont work ect ect. i replaced the battery. it was working before. i could jump the car off and tons of stuff lit up so im pretty sure its the battery. i checked a bunch of fuses. all the ones i checked = good.
oh, and does anyone have a picture of the under dash gxe fuse diagram cuz mine is gone
Old Apr 21, 2008 | 10:38 AM
  #793
Greeny's Avatar
¯\(°_o)/¯
See if this will help, it's from 94 se, but most are the same.
BTW, which year maxima do you have?
Old Apr 21, 2008 | 11:03 AM
  #794
Greeny's Avatar
¯\(°_o)/¯
Huh?
Old Apr 21, 2008 | 11:58 AM
  #795
Huh?
see, what happened, is that the internet cut out in mid-submit, so half of the filestream reached the server and the rest was lost in the airwaves.
what i was trying to say was that my GXE's fuse locations are quite different. my fuel pump fuse, for example, is midway down the left row.
(i'm using the WiFi from next door and the signal gets crappy from time to time, like when planes are overhead... we're about 1 mile from the airport.)
Old Apr 21, 2008 | 12:04 PM
  #796
Greeny's Avatar
¯\(°_o)/¯
OIC..Thanks..
Old Apr 21, 2008 | 05:23 PM
  #797
viperbite's Avatar
omg i love you.
thanks so much!
hahaha
says manufactured in 1990 somewhere on the car. then another place says 01/1991 so im asuiming its techincally a jan 1991 car.
Old Apr 21, 2008 | 05:58 PM
  #798
BenStoked's Avatar
Jesus was a Zombie.
omg i love you.
you can check your vin codes to be sure what year it is for sure
http://forums.maxima.org/showpost.ph...9&postcount=54
Old Apr 21, 2008 | 06:04 PM
  #799
this is from a 90 GXE
Old Apr 21, 2008 | 06:58 PM
  #800
viperbite's Avatar
horralyyyy!!! love you too !
lol!
*no homo*
ill rep yall... if mine are worth anything lirl
okay i cant rep anyone... cool
