buying window regulator from ebay need help
Old Jul 22, 2008 | 12:21 AM
mokylim's Avatar
im about to buy my replacement window regulator from ebay. tell me what you guys think of this seller and the part that im about to get and the price. Ill be replacing the one on my side (drivers side). heres the link.
http://cgi.ebay.com/ebaymotors/_Car-...3756.m14.l1318
Old Jul 22, 2008 | 01:27 AM
Pearl93VE's Avatar
I can has?
Is the motor bad too? A lot of times the motor's are fine (If you push the button you can hear it) and just the regs fail. If that is the case, you could save yourself $30 and get this one:
http://cgi.ebay.com/ebaymotors/WINDO...QQcmdZViewItem
Old Jul 22, 2008 | 01:34 AM
jonmandude's Avatar
I have purchased turn signals from them. The parts fit well and look good, but it doesn't feel like the same quality as the OEM. For me I prefer to spend the money for the OEM. I always know it will fit and last.
Old Jul 22, 2008 | 10:24 AM
mokylim's Avatar
hmmmm.......you know what i did remember the motor was working when i took it off the car. whenever i tried using the window there would be this winding sound but stops when the wires get stuck. so is the motor still good then? thatll save me 30 bucks if it is.
Old Jul 22, 2008 | 10:34 AM
Pearl93VE's Avatar
I can has?
Yep, if there is sound coming from the motor it is still fine. Just bolt the new regulator to the motor when you get in there and it should work fine. It has for me the past 3 times anyway... the motor's are pretty durable.
CapedCadaver's Avatar
Call me Wookiee Goldberg
yea save yourself a few $ then
Old Jul 22, 2008 | 10:46 AM
mokylim's Avatar
what about the wires though?? im pretty sure they were all either tangled or messed up around the regulator. and im not sure if it is with the motor even
Old Jul 22, 2008 | 10:54 AM
what about the wires though?? im pretty sure they were all either tangled or messed up around the regulator. and im not sure if it is with the motor though.
the wires should plug into the harness and go straight to the motor. pull the entire unit out as a whole piece and take a look at it. if the motor turns and the wires are not messed up real badly (exposed wire, etc) then keep the motor part.
Old Jul 22, 2008 | 10:59 AM
Pearl93VE's Avatar
I can has?
The motors electrical wiring? I doubt that happened. All that is connecting the motor to the regulator are the two cables. Once you remove the reg from the motor you'll see what I'm talking about. But the point is, if you hear it... it's fine, if you don't hear it, get a motor.
Old Jul 22, 2008 | 11:02 AM
mokylim's Avatar
well i think they are all messed up since i before it took them apart i tried looking into the thing too see how it works, after winding for about 3-5 sec. it would get stuck since the wires are all tangled around the regulator but im pretty sure the motors are working fine.
Old Jul 22, 2008 | 11:04 AM
mokylim's Avatar
when i say wires that are tangled i meant the ones that are in the white pulley right under the window sill. need to get out and check hold on
Old Jul 22, 2008 | 11:12 AM
Pearl93VE's Avatar
I can has?
Oh, so you mean the thin regulator cables? Yeah, that is why they fail. They break/come apart and get really loose and it's possible they can wrap around the regulator or window once they have slack. Just make sure to route them nicely when you install your new regulator; making sure the windows full travel doesn't affect them at all.
Old Jul 22, 2008 | 11:17 AM
mokylim's Avatar
yeah the one that are like metal wirings. they got all tangled around the regulator. your sure theyll be fine once i install them with the new one?
Old Jul 22, 2008 | 11:26 AM
they are part of the one that Pearl linked you on post #2. the motor is just held on by 3 chunky screws. you'll see what you have to remove once you get the replacement regulator, simply by seeing what's on one and not on the other.
Old Jul 22, 2008 | 12:03 PM
Pearl93VE's Avatar
I can has?
Yeah, all those "wires" are part of the regulator. Don't worry about them since you'll be throwing it away.
Old Jul 22, 2008 | 01:41 PM
mokylim's Avatar
alright cool...will order right now.will update u guys once i get it installed.thanks for all your help!
londonflu
40
Sep 25, 2015 09:11 AM
markevans999
Sep 10, 2015 04:29 PM
ef9
Sep 5, 2015 11:18 PM
maximusrising
Sep 4, 2015 06:31 PM
A32goldylocks
Sep 2, 2015 06:39 AM
