Fuel Injectors Purchasing
Hello all. I have done a search on the forms for fuel injectors and have come up with so many different options. Can someone lead me into the correct way in purchasing fuel injectors. I have a VG30 GXE SOHC. I hope these are not to ridiculously expensive.
![Confused](https://maxima.org/forums/images/smilies/confused.gif)
Yes, they are ridiculously expensive.
This is the best place to purchase them--> http://internetautosupply.com/catalog/
He is our long time member internetautomar/aka brian.
![Smilie](https://maxima.org/forums/images/smilies/smile.gif)
He is our long time member internetautomar/aka brian.![Smilie](https://maxima.org/forums/images/smilies/smile.gif)
what is the difference between
Fuel Injector with Green Marking $115.00
Fuel Injector with Yellow Marking $115.00
what is the difference between![Confused](https://maxima.org/forums/images/smilies/confused.gif)
i know there was a design change from 92 to 93 but i dunno if that's what the dots are representing.
89-92 VG have a thick connector on the injector and have both been superseded to 1 part #.
93/94 have a thinner connector which is the same configuration as the 92-99 DOHC maximas, but it has 2 options which is determined by the paint dot that is on the injector's connector. pick any injector on the car and take off the connector and then you will hopefully see the dot on it.
I do not know what the dot differentiates, so unless you are doing all 6 check the dot before ordering.
06-06-2017 02:01 PM
Forge277
06-13-2016 09:26 PM
