Horn stopped? and brotherly war question.
Old Dec 25, 2008 | 04:59 AM
Mysticcal's Avatar
So. I made the fun fun drive of SF to LA for XMAS with the family. good times had allround. temp went below minimum driving through grapevine... guess thats normal for the east coasters in winter though?
My horn stopped working... press button nothing... I read the Cruise Control is somehow connected with the horn (least I think I read when I was lurking) so it might be the horn itself? or the Horn relay?
any advice would be much helpful
also. could my 94 SE give my brothers 07 Altima a run for his money? :P apparently our cars have the same HP. but no doubt he has a much faster 0-60 than I do
Old Dec 25, 2008 | 05:17 AM
CapedCadaver's Avatar
Call me Wookiee Goldberg
also. could my 94 SE give my brothers 07 Altima a run for his money? :P apparently our cars have the same HP. but no doubt he has a much faster 0-60 than I do with a 4cyl
well... yes, the CC and horn circuits do share some wiring. I'm guessing you mean to say that your cruise control works just fine? Anyhow, I guess I would start with checking the horn relay. Because I have never had an SRS steering wheel and therefore, don't know jack crap about it, and couldn't tell you where to start trying to mend the horn switch if it's at fault. All I can say for sure is that if the brown and white wire on the horn relay harness IS continuous to ground when you push the horn switch, then the horn switch works.
Old Dec 25, 2008 | 07:42 AM
internetautomar's Avatar
mod or sell?
on an SRS equipped car, it uses a ribbon of wires wrapped up so that it always stays connected no matter how far the wheel is turned. Those wires do break over time, so if your only problems are the cruise buttons on the wheel and horn not working (should get an airbag light too) then it is probably that cable that has failed. The FSM calls it a spiral wound cable, while the aftermarket calls it a clock spring.
Old Dec 25, 2008 | 08:05 AM
BenStoked's Avatar
Jesus was a Zombie.
one time, I punched my steering wheel, breaking the horn
trip to the junk yard for a new horn button fixed it
Old Dec 25, 2008 | 11:38 AM
Mysticcal's Avatar
sorry. meant to say my cruise work. and..... my airbag light isnt on.
thanks for all the help. with any luck. it'll be fixed sometime in 09.
Old Dec 25, 2008 | 08:22 PM
mod or sell?
then I would check the horn relay, horn fuse, and the the steering wheel itself.
actually in order:
Horn fuse
Horn itself
horn relay
steering wheel
Old Dec 25, 2008 | 08:58 PM
gapboi210's Avatar
I am not sure if youur brother's Altima would beat the Max. I am guessing it would. Newer Nissans use more aluminum and other lightweight materials all over, espcially in the body. They have advanced variable timing, more modern fuel delivery, ignition, and engine management systems and are able to reach higher rpms faster. Better transmissions, better gearing, less power loss in the drivetrain. If you decide to find out TAKE IT TO THE TRACK!
Old Dec 26, 2008 | 10:20 AM
mod or sell?
compare HP to wt ratios.
Old Dec 26, 2008 | 11:11 AM
sleepyvg30e's Avatar
the maxima would win
93 maxima se
190 hp 5600 rpm
190 ft-lbs. 4000 rpm
07 altima
150 hp 5600 rpm
154 ft-lbs. 4400 rpm
Old Dec 26, 2008 | 11:43 AM
BenStoked's Avatar
Jesus was a Zombie.
93 maxima se
190 hp 5600 rpm
07 altima
150 hp 5600 rpm
not too sure where you got the info for the altima engine, so:
Originally Posted by Wiki
The 2007 Altima uses revised versions of the engines from the third generation model. The VQ35DE 3.5 L V6 engine produces 270 hp, and the QR25DE 2.5 L I4 produces 175 hp (130 kW).
and hp is not the only factor. any racer will tell you that.
i have doubts that a 14-5 year old car will beat a car that is less than 2. especially considering that the older car may not be at its peak performance.
not saying the max will lose, but I wouldn't be too sure.
Old Dec 26, 2008 | 12:22 PM
actually it was 3 engines that came for the 07 altima my bad the stats above were from the 97 altima
270-hp @ 6,000 rpm
258 lbs.-ft. @ 4,400 rpm
175-hp @ 5,600 rpm
180 lbs.-ft. @ 3,900 rpm
170-hp @ 5,600 rpm
175 lbs.-ft. @ 3,900 rpm
Old Dec 26, 2008 | 07:52 PM
Pearl93VE's Avatar
I can has?
I know for a fact that my VE can beat a 2.5 5-spd Alti, raced my friends, and he also got walked on by a late model dodge dakota.... granted, his is a 2005.
at the track of course.
Old Dec 27, 2008 | 09:31 PM
Mysticcal's Avatar
I fixed it. took off the griill and some blockhead previous owner fixed it before (i guess?) and the wires were once cut... and they were just twisted back. soldered and heatshrunk. back in business
though 1 cable to going to 1 of the horns was also broken so only 1 tinny horn :P
my brother tells me he has 190HP as well.. probably not going to the track since we're not THAT competitive. it's all in good fun.
D Mason
Jun 21, 2016 04:43 AM
doctorpullit
Mar 29, 2016 11:08 AM
BobTX10
Oct 7, 2015 08:43 AM
maxima297
Sep 30, 2015 03:32 PM
