Dash Lights Intermittent
Old Apr 4, 2009 | 12:23 PM
fattamax's Avatar
Wow it seems like every thread that I have looked at in the last three or four weeks my car has had this problem. I cant remember who it was talking about how to repair this but i need some help. The lights were slow to come on and then the next day no problem. The day after that they started to flicker on and off and then totally dead. Someone please help!
Old Apr 4, 2009 | 06:19 PM
Hectic's Avatar
Replace or repair your headlight/turn signal switch.
When they're not on, you have no tail lights, keep that in mind.
Old Apr 5, 2009 | 03:16 AM
fattamax's Avatar
Never done this before. I am guessing that this is going to be a steering wheel removal to replace this unit. Any guidance?
Old Apr 5, 2009 | 04:27 AM
Niccos89's Avatar
Under the steering collumn cover, there are 7 or so screws (I found some were missing in mine from previous ownership), then the top half and bottom half just pry apart. Its actually pretty easy - I was expecting Hell when I went to do my blue ignition barrell light, took me 5 minutes in and out.
Old Apr 6, 2009 | 12:02 AM
maxinout93's Avatar
Hi, there is a light around my ignition switch that seems to stay lit up at night. Once I leave the car, and lock the doors, seems like the light around the ignition switch just stays on. Is this normal, Or do I have some type of Issue?
Old Apr 6, 2009 | 01:34 AM
Niccos89's Avatar
All your doors shut properly?
Old Apr 6, 2009 | 07:24 AM
maxinout93's Avatar
Well the driver side door seems as if there is a shortage in it. When I close the door sometimes the interior door lights stay on, and I have to hit or push the door for them to go off. I will try to pull the panel off today and see whats going on in there, because my keyless entry stopped working also.
Old Apr 6, 2009 | 07:34 AM
Greeny's Avatar
¯\(°_o)/¯
Stop jacking everyone's threads with your problems! Either start your own thread, or post in the noobie thread..
Old Apr 6, 2009 | 07:45 AM
internetautomar's Avatar
mod or sell?
IIRC it stays on for a few minutes after a door is opened
Old Apr 7, 2009 | 03:07 AM
fattamax's Avatar
So what you are saying Nicco is that i dont have to remove the steering wheel? I hope not because I use to have a Beretta GTZ and thats what I had to do...sucked ***** too !!! Let me know and I appreciate the guidance and help.
Old Apr 7, 2009 | 07:48 AM
BenStoked's Avatar
Jesus was a Zombie.
you do not have to remove the steering wheel. just the shroud around the steering shaft.
Old Apr 7, 2009 | 10:54 AM
fattamax's Avatar
Cooool thanx everyone for your guidance and help. And Maxedout you should probably check all your door pins and make sure they are connected and or not corroded. ( and stop jackin threads )
mvm062
Nov 30, 2020 09:00 AM
Smackasmith
Feb 1, 2016 12:40 AM
fastcarny
Oct 6, 2015 10:42 AM
rnb754
Sep 14, 2015 11:39 PM
Maxima30
Sep 7, 2015 06:13 PM
