power steering pump
Old Jun 22, 2009 | 02:48 AM
MaximaFan4140's Avatar
power steering pump
ok can anyone post a link or something that shows me how to replace my power steering pump, belt and hoses with all the little tricks of the trade after doing it?? seems to me like it would be a PITA and time consuming...im not much of a hardcore DIYer but i can manage sometimes lol
Old Jun 22, 2009 | 11:23 AM
1993-VG30E-GXE's Avatar
Search on it - there's posts about the pwr steering pump every two weeks, in this particular forum.
It's very easy, there's only 7 bolts or so you need to un-do. You access from the side splash panel that covers the belts.
Old Jun 26, 2009 | 11:53 PM
CMax03's Avatar
The pump itself is only held in by 3 bolt on it's front and 1 bolt on the back.... jack up the car and remove it after you break the lines loose.
Old Jun 30, 2009 | 07:15 PM
ILoveMy1992Maxima's Avatar
Ok I have a question. I change my power steering pressure hose and bleed it. The problem Im having now is when I turn the steering wheel its making the sound like its low on power steering fluids. I check it and its full to the top. Does anybody have any suggestion>? Can it be the power steering pump? Thx you for ur help
Old Jun 30, 2009 | 07:35 PM
James92SE's Avatar
2 VE's are better than one!
It probably needs to be re-bleed..
Although, for what it's worth, I replaced my power steering hose with an aftermarket one and no matter what I've done it still whines. From what I can gather on here, several others have had similar symptoms with the aftermarket hoses for some reason
Old Jun 30, 2009 | 07:48 PM
internetautomar's Avatar
mod or sell?
the theory is incorrect inside diameter on the replacement hose.
Old Jun 30, 2009 | 08:14 PM
CMax03's Avatar
While in park and idling, turn your steering wheel to extreme left and extreme right until all the fliud is within the system, continue and top off as necessary to prevent from sucking air into your system. It will make a little noise until all the air is depleted and your system is completely liquid!
Old Jun 30, 2009 | 08:35 PM
I did that but it still whines. When turning to hard left and hard right the power steering fluids makes bubbles.I cant put no more power steering fluid in because its to the max.
Old Jun 30, 2009 | 08:37 PM
CMax03's Avatar
If it's making bubble there's still air in the system be patient and keep cycling the steering!
Old Jun 30, 2009 | 08:46 PM
So should I continue turning the steering wheel hard left and right>? Are will it take care of it by itself?Thx for your help
Old Jun 30, 2009 | 08:50 PM
Greeny's Avatar
¯\(°_o)/¯
The bleeding procedure per FSM
1. Raise front of vehicle until wheels are clear of the ground
2. add fluid into tank to specified level, turn steering wheel quickly from left to right,lightly touching the steering stoppers..repeat procedure until fluid level stops going down..
3. Start engine, then repeat step 2 with the engine running...
Old Jun 30, 2009 | 09:00 PM
thx u will try that tomorrow hopefully that works.
Old Dec 20, 2009 | 06:09 AM
biggz2332's Avatar
Ok mines doesn't make a noise but at idle the wheel is hard to turn and as the cars speed increases it's easier to steer is this the pump?
Old Dec 20, 2009 | 06:46 AM
mod or sell?
as the RPM of the motor increases or as the car's speed increases?
Old Dec 20, 2009 | 08:55 AM
biggz2332's Avatar
sry for being so unclear but the cars speed.
lowpost99
Oct 26, 2025 06:53 PM
RWCreative
Sep 21, 2015 11:01 AM
imported_Nismo_max
Sep 20, 2015 08:19 AM
rnb754
Sep 14, 2015 11:39 PM
SusieQQ
Sep 9, 2015 12:14 PM
