driving without alternator adjustment bolt
Old Jul 11, 2009 | 02:12 PM
YearOfTheGus's Avatar
Is it possible/safe? Mine snapped while I was trying to get the belt tight. I was thinking that the two bolts that you have to loosen in the first place to adjust the belt would be enough to hold it still, but I'm not quite sure.
Old Jul 11, 2009 | 04:05 PM
CapedCadaver's Avatar
Call me Wookiee Goldberg
well, technically you don't need the adjuster once everything is tight; all you need to hold belt tension is the lockbolt. but it's not gonna be easy to get it tight w/o that tensioner bolt.
Old Jul 11, 2009 | 04:38 PM
yeah I can't even move it by hand. :P
I'm trying to order an extra bolt and the adjuster block that it goes into (looked like threads were coming out when I was getting the remainder of the bolt out) but their checkout page isn't working. I guess I'll just try again monday or stop by the stealership.
Also, kind of off topic, but does anyone know where the diagram with the splash guards is on the Courtesy Parts website? I've looked but can't find them for the life of me.
Old Jul 11, 2009 | 04:55 PM
should be easy to find at a JY.... any VG will use the same one, so as long as there's one there with it, should just be a few dollars if they even charge you for it
Old Jul 11, 2009 | 07:31 PM
maxinout93's Avatar
Pick up one from the local junk yard. The dealer charges like $70 bucks for those things. My mechanic Broke my power steering adjustment bolt when he did my water pump and didn't tell me. I had to figure it out myself after I drove the car and it would squeak so loudly whenever I turned the wheel, as if the belt wasnt on tight enough. So i go to look for the adjustment bolt and what do i find?? Its in peices!! I got one from the JY for like $5. problem solved!
Old Jul 11, 2009 | 07:38 PM
Evil Ryu's Avatar
damn 70 bucks? i paid 95 bucks for my rebuilt hitachi alternator.
it works, but when i hooked up the battery, the alternator smoked?
i wonder if i hooked it up wrong..anyways...lol
lowpost99
Oct 26, 2025 06:53 PM
matts95max
Apr 23, 2025 10:44 AM
The Frye
Sep 2, 2021 11:03 AM
Maxima30
Sep 7, 2015 06:13 PM
dcardello
Sep 3, 2015 11:44 PM
