Suspension Upgrades
Old Aug 26, 2009 | 06:43 AM
cardana24's Avatar
Blown
Suspension Upgrades
A lot of people have been posting suspension threads and questions lately so I did not want to be left out so here is my thread documenting my suspension upgrades.
here are a bunch of the parts I started out with. ST springs and front and rear sway bars, tokico struts, Blemco rear sway bar end links. Not pictured is a new left side axle, Z31 rear rotors, and moog outter tie rod ends.
I got a full stock set up from a 90 SE in the junk yard so I could swap all of my new stuff onto this and keep the stock set up. This will also allow me to run the Z31 rear rotors.
here is how I did the rears. Compress the springs to take them apart. Then put it in the vise to get the gland nut loose. Then I put the top of the sturt in the vice and banged down on the lower spring pearch with a rubber mallet to get the stock cartridge to come out.
Old Aug 26, 2009 | 06:50 AM
cardana24's Avatar
Blown
Then I realized that the stock gland nut would not hold the tokico cartridge in, I even tried taking out the stock seal to see if that would make enough room. (Hopefully I will have the gland nuts soon)
So I moved on to the front. The process was the same for taking told spring off and putting the new one on. I also added new KYB dust boots and bump stops. I did not cut the KYB bump stops (I normally cut the stock ones in half when I lower a vehicle) because they were about half the size of the stock bump stops. I also took the front sway bar off and put the new ST one on. While working on the front I noticed that the axle I just put in a few months ago was throwing grease so I got another one from NAPA, and put that in while I have everything apart. This is also the time that I replaced the outter tie rod ends. Here are a few pics of things going on in the front.
Old Aug 26, 2009 | 06:54 AM
cardana24's Avatar
Blown
here are a few more pics of work on the front.
I don't really have any questions at this point. If you guys have any questions or comments please feel free. I will post up more on my progress when I get the gland nuts in and can move forward with the rear. Currently the car is lowered in the front. Has a ST front sway bar installed, along with new moog tie rod ends, and a left side axle.
Old Aug 26, 2009 | 07:31 AM
All*Pro's Avatar
Great pics documenting the whole process. Most 3rd gen guys nowadays tend to go with Eibach, Sprint, or Intrax springs, and you rarely see anything on Suspension Technique springs. I've always liked and have been curious about the ST's, what swayed you to choose that setup?
Old Aug 26, 2009 | 07:41 AM
cardana24's Avatar
Blown
Well I know ST makes good stuff. I ran ST springs on my second gen, and I was happy them. Also it does not hurt that I found a guy selling springs and sway bars on ebay (all of the stuff was NOS). I offered him a pretty low price for both sway bars and the set of springs and he took the offer...so that is the main reason I went with all ST.
Old Aug 26, 2009 | 11:49 AM
CapedCadaver's Avatar
Call me Wookiee Goldberg
nice work... i expect no less from the best-in-show winner at Maxus.
how close is the tierod end to the swaybar? one of those pics makes it look AWFUL close to the top nut on the endlink.... optical illusion?
Old Aug 26, 2009 | 12:01 PM
James92SE's Avatar
2 VE's are better than one!
Pretty cool. Glad to see you really going at it on the VE.
Have you thought about sub-frame connectors? I've had a set for years but have never gotten around to putting them on
cardana24's Avatar
Blown
I'll check it, but I don't remember anything looking out of wack. All of those pictures are taking at a downward angle too, so it may make them apear closer than they are.
My gland nuts came in today from Tokico, so hopfully tonight I can knock out the back.
Old Aug 26, 2009 | 12:09 PM
cardana24's Avatar
Blown
Thanks.
Yes I have thought about SFC's and I may do those in the future just not right now. I hope to run this car at Summit Point, WV (semi local) when they do a HPDE (high performance driving event) or at VIR, and knowing me this car will also see the drag strip too.
Old Aug 26, 2009 | 12:17 PM
marke's Avatar
I have Suspension Techniques springs on KYB struts. I like the ride, but all I have to compare it to is a worn out oem set-up.
Depending on your wheels & tires you may have to roll the rear fenders...
Old Aug 26, 2009 | 12:39 PM
cardana24's Avatar
Blown
What is your wheel and tire set up (i.e. sizes)? Are your fenders rolled? I want to space my current wheels out as far as possible with out rolling the fenders in the front. I assume when the front is rolled you loose the fender liner, is this true? I worry about that because my intake is just behind the fender liner. I will have the back rolled that is not a big deal.
Old Aug 26, 2009 | 12:56 PM
99% chance that's what i saw then. it was this pic i was referring to
Old Aug 26, 2009 | 01:00 PM
cardana24's Avatar
Blown
I would not really base the relative closeness of any parts off of that picture. If you will notice the axle is out, the strut is out, I am not sure which way I had the knuckle/spindle facing at that moment. also the sway bar has not been tightened down in that picture, if you will notice in the later pictures you can see more thread at the tops of those bolts.
Old Aug 26, 2009 | 03:18 PM
James92SE's Avatar
Regardless of picture angles or anything, I can definitively say that the ST sway bar doesn't come close to interfering with the tie rod or vice versa
Old Aug 26, 2009 | 04:05 PM
marke's Avatar
The front wheel well is bigger than the back, so I wouldn't worry about the front. My wheels are from a 2000 maxima (16x7 40mm offset) and my tires are 215/55/16. They are close to the strut, but not too close to the fender. I was looking at some 18's and I would've had to get the rears rolled if I put them on (350z touring 18x8 30 mm offset 235/40/18).
Old Aug 26, 2009 | 08:15 PM
cardana24's Avatar
Blown
Okay I have a question about the Blehmco rear sway bar links. On the part that hangs down from the bracket that you bolt your bushings to. Does that require and nut above the block that the bushings bolt to and one below it? The picture that came with the links look like there is a nut above and below the block, but the set I got only came with one nut/washer/lock washer per hang down side, but the block is threaded. Are you supposed to put one nut above the block to act as a jam nut and just thread the bolt until it is flush the the block on the lower side? I am guessing this does not make since unless you have done this swap so hopefully some one will chime in so I can finish up the rear.
Also one other question about the Blehmco rear links. Do you use the bracket and self tapping screws if you are using the stock bracket that is already on the car? I am guessing you use the "L" bracket and the self tapping screws if you are going to have it welded. Anyone know?
I made good progress tonight but I am not finished. I got both rear struts/springs swapped and started working on the sway bar install but got hung up with the rear links.
Old Aug 26, 2009 | 08:18 PM
Maximan190's Avatar
nice documentation.. i almost forgot what the underbody of these cars look like fully assembled
did you replace the insulators or the bearings on the struts?
#54320 and 54325 here
are you going to run camber bolts or something of the like up in the front?
Old Aug 26, 2009 | 08:23 PM
James92SE's Avatar
Yes
Well, you use Matt's angle iron bracket ("L" bracket) in PLACE of the stock bracket. So, if the stock bracket is still on there, you'll want to take it off (shouldn't be much effort), and then put Matt's bracket in its place. I believe he supplies the self-tapping screws for those who can't/don't get it welded. Ideally, you'll want to get it welded. If you don't have a welder, mount them on with the self-tapping screws and then just get a muffler shop to weld them up.
*edit* to expand on Maximan's post, you definitely want to run some camber bolts. With the ST's you'll have pretty negative camber. I was kind of skeptical of camber bolts at first but I've been running them for 5+ years now with great success. They're pretty neat little suckers. If I adjust them all the way out I can even get POSITIVE camber on my car and that's slammed with Intrax springs.
Old Aug 26, 2009 | 09:40 PM
CMax03's Avatar
Cardana24,
I chose to go with ST, since they were one of the first companies to offer dropped suspensions for car/trucks since the earlier 70's...Along with them were Addco who offered the largest line of swaybars for vehicles since 1962.
My setup is KYB GR-2's, ST swaybars Front/Rear, and ST lowered springs and It's getting closer to rolling. Mine are metallic grey like yours instead of that vomit green, here's a stance shot:
Old Aug 26, 2009 | 10:42 PM
kringle03's Avatar
What's the drop with the ST spring setup?
To go along with Jeff, you are definitely going to want some camber bolts up front, and if your going more than a 1.2" drop some adjustable arms for the rear.
Old Aug 27, 2009 | 12:42 AM
maximo018's Avatar
Damn you got everything I got except for sprints and rotors are different and I haven't mounted any of mine yet.
Old Aug 27, 2009 | 06:10 AM
cardana24's Avatar
Blown
No, mine seemed to be in good shape. I was not planning on running camber bolts but by the other posts it sounds like I should.
Yes
Matt's "L" bracket is stronger than the stock bracket even if it is held in by self tapping screws?
We really cannot get our camber in spec in the front with out camber bolts?
Originally Posted by CMax03
Cardana24,
The car is looking good. I remember when you sent me a picture of it with out the engine in the car.
I don't remember the advertised drop. It's a little more than the Eibach set up, but not as much as the sprint/intrax if I remember correct.
Is any one here really running adjustable arms in the rear?
Well get on it.
Old Aug 27, 2009 | 06:12 AM
cardana24's Avatar
Blown
Also, with the camber bolts, have any of you that have them autocrossed/road raced with them? Usually they are just a skinnier bolt, so I want to make sure strength is not an issue.
Old Aug 27, 2009 | 06:52 AM
kringle03's Avatar
Well get on it.
Yes I'm running (Oh crap... SPC? Adjustable rear control arms...) I believe that's right, I'd have to double check my paperwork. And I'm Eibach camber bolts up front and they work like a champ!
The Eibach spring set up is 1.2" I'm running B&G springs with a 1.6" drop and the camber bolts and adjustable RCAs were definitely necessary!
Old Aug 27, 2009 | 06:56 AM
cardana24's Avatar
Blown
Thanks for the info^^
Would this kit cover me?
http://shop.advanceautoparts.com/web...5_714769162___
It's in stock at my local advanced store. What are the wedges for? I know how the bolts work.
How is everyone else getting by in the rear with out adjustable RCAs?
Old Aug 27, 2009 | 07:44 AM
James92SE's Avatar
Well, those aren't really the "adjustable" camber bolts, but I suppose it has the same purpose. Wedge goes behind the bolt to keep it tight I guess. I mean, if the bolt is skinnier than the hole on the strut, there's nothing to keep it from "sliding" within the hole, so the wedge is jammed in behind the bolt to keep it tight.
The adjustable camber bolts have a lobe sort of thing on them, and a washer that you turn to adjust the camber. It's the style I have. Anyway, no, the camber on 3rd gens is non-adjustable so it can't be put in spec at all after a drop without camber bolts or something custom.
Old Aug 27, 2009 | 07:55 AM
cardana24's Avatar
Blown
Okay. I'll order some eibach camber bolts.
So you are saying I need adjustable rears too? Where are you guys picking them up?
Old Aug 27, 2009 | 08:29 AM
cardana24's Avatar
Blown
I just ordered the eibach camber bolts from the sponser here, import car parts in the GD section.
Whats the most cost effective way to go on the rear?
Old Aug 27, 2009 | 08:34 AM
James92SE's Avatar
On the rears you can actually just use stock parts. IIRC one all you need is to gather another set of adjustable parallel links, thus making them adjustable on both sides (I think one per side stock is not adjustable). It's been probably 6+ years since I've messed with them so I don't remember the specifics
*edit* by "side" I mean one side (one of two on each side of each strut) per side of the car, if that makes sense..
Old Aug 27, 2009 | 08:54 AM
cardana24's Avatar
Blown
Got links?
so I need more parts from the junkyard? I could possibly hit a yard this weekend but I need to know what to get.
Old Aug 27, 2009 | 08:59 AM
James92SE's Avatar
Got links?
http://forums.maxima.org/3rd-generat...-3rd-gens.html
Old Aug 27, 2009 | 09:16 AM
cardana24's Avatar
Blown
okay, so it looks like one parallel link is adjustable on each side and the other one is fixed. So what that is saying is pick up another adjustable link for each side and replace the fixed one?
Also who stocks the energy suspension bushing for the rear links? According to courtsey nissan it is a special order item and it could take up to a month to ship.
Old Aug 27, 2009 | 09:28 AM
James92SE's Avatar
Yep, that's exactly what to do
Sorry, no clue on that one
Old Aug 27, 2009 | 11:09 AM
cardana24's Avatar
Blown
Okay well how about this option. Rather than trying to find a bushing set that will take month for me to get and going to the junk yard to pull parts (gas/time/$) shouldn't I just get these? New parts and they already have poly bushings installed.
What do you guys think?
http://www.sportcompactonly.com/Niss...-5806_m-20.htm
here is the SPC kit, even with shipping its under $100
http://www.sportcompactonly.com/Camb...-78528_s-0.htm
Old Aug 27, 2009 | 12:53 PM
kringle03's Avatar
Here's a slightly better price (I ordered from these guys)
Front: http://www.internetautosupply.com/ca...c590a918731d7a
These bolts don't have a wedge for movement either, it's based on a tab that's on the washer.
Rear: http://www.spcperformance.com/PROD_D...d2=67010&cmd3=
Old Aug 27, 2009 | 01:02 PM
cardana24's Avatar
Blown
I he is a third gen guy, I did not know that he sold parts like that, I just thought he had stock replacements. Anyway, I have already bought a set of front eibach camber bolts.
*Also I called SPC based on this link you provided. The posted price is per side. I have found the SPC set of both sides for ~120.
Also in the link I posted above, I am not sure sport compact only is still in business. All of the numbers they have on their site do not work.
Old Aug 27, 2009 | 01:38 PM
kringle03's Avatar
I need to find my receipt... I don't remember paying $140+ for my rears...
Old Aug 27, 2009 | 06:02 PM
James92SE's Avatar
Yep, that certainly sounds like a plan. If you wanted to go really hardcore you could get Matt's kit
Old Aug 27, 2009 | 10:00 PM
CMax03's Avatar
St spring are only a 1.6" drop in the rear and front! I'll see what is gonna be needed for alignment, but so far, I don't see anything obviously misaligned that bad! But that alignment rack is definitely more accurate than my eyes!
Old Aug 28, 2009 | 12:00 AM
maximo018's Avatar
Easier said than done. We're doing body work now. And she's got to be painted. So I'll wait until after she's painted to do this. My suspension upgrade will top all. I'm having everything that could be done to a 3rd gen done (including stage 1-3 sbfc). This will be my toy that I will enjoy taking to the track now and then. But as for yours so far so good. Looks nice!
