Starts, runs a few seconds and dies...
Old Aug 28, 2009 | 06:45 PM
nitrous360's Avatar
I was coming to a stop the other day and my Max just died. It will start for a few seconds then it dies. I checked the TPS and it is fine, swapped the MAF still the same. I have no engine light, but I'm still going to check for codes. It sucks because I'm so busy with work and when I get some time it rains. I recently replaced the injectors, cleaned the IACV, all new vacuum lines, new cap rotor, plugs, wires and timing belt. I'm thinking either try changing the CTS because it's cheap and if that doesn't work look at the CPS which sucks because it's expensive.
I really do love the car but I'm tired of fixing it. I got 150k on it and I still have to replace the fuel and brake hard lines because of rust, change all struts, mounts and springs...
Old Aug 28, 2009 | 09:02 PM
LvR's Avatar
LvR
Check fuel pressure when the car dies - if pump/filter/FPR is fine the pressure will remain around 40psi for minutes once switched off..........
Old Aug 28, 2009 | 10:27 PM
1993-VG30E-GXE's Avatar
In the FSM there are diagnostic charts for your symptom. Those could help point you in the right direction.
Old Aug 29, 2009 | 09:20 AM
nitrous360's Avatar
Will do, if it stops raining around here. I finally have the time and the weather turns for the worse. I miss my old garage let me tell ya.
Old Aug 29, 2009 | 10:31 PM
Big_E-Dog's Avatar
2nd Gen Boostinator
was hapening to me and i unplugged the o2 sensor and it works fine now....
Old Aug 29, 2009 | 10:39 PM
burhan92SE's Avatar
does it die wen its cold? or it doesn't matter if its cold or hot?
Old Aug 29, 2009 | 11:35 PM
CMax03's Avatar
Check your fuel system!
Old Aug 30, 2009 | 01:20 PM
nitrous360's Avatar
Well, it's finally not raining and I got a chance to check for any stored codes. I got a code 12 MAF sensor. I unplugged the sensor and it will run so it's a bad MAF. I have one lying around but it has 4 prongs and the one I have has 5 prongs??? Why is this? Anyone know?
Old Sep 3, 2009 | 07:21 AM
internetautomar's Avatar
mod or sell?
don't matter, as long as it is from a 3rd gen maxima it is compatible
MattWithTheMaxima
Jun 30, 2017 01:06 PM
homeyclaus
Sep 3, 2015 06:15 PM
305head
Aug 26, 2015 09:03 PM
beboski
Aug 16, 2015 05:23 PM
doobadoo
Aug 15, 2015 06:43 PM
