Ignition problems
Old Sep 21, 2009 | 05:46 AM
W00dface's Avatar
Ignition problems
I recently wired in a start / kill switch. done it in bit of a rush and taped the connectors. Gone out this morn to properly connect them all to find that the engine wont start.
getting the accessory power, dash lighs and hearing the relay click, but nothing when I connect ignition
Checked Fuses in Passenger compartment and engine bay. Changed relays. Still nothing
Old Sep 21, 2009 | 06:10 AM
W00dface's Avatar
Put the origional key switch back in to rule out bad connection with starter switch. Still the same thing
Pretty sure something has blown somewhere, just can't find it.
Old Sep 21, 2009 | 06:12 AM
CapedCadaver's Avatar
Call me Wookiee Goldberg
undo everything to do with that switch (back to stock) and then see what happens
Old Sep 21, 2009 | 06:13 AM
W00dface's Avatar
Sorted.
Whilst fiddling under the dash, I must have knocked the auto stick in to 'r'
Old Sep 21, 2009 | 06:16 AM
Originally Posted by W00dface
Sorted.
wat? UK doesn't have a brake pedal lockout for getting out of park? i know some/all UK cars don't have the clutch-safety switch (as seen on Top Gear when Hamster got hypnotized and forgot how to drive, and started the car while in-gear)
Old Sep 21, 2009 | 06:35 AM
W00dface's Avatar
Nope. To get out of park, you need to press a button on the side of the auto stick, but mine is a bit knackered
I dont know of any cars over here with the clutch saftey. Certainly none that I have had.
Old Sep 21, 2009 | 06:49 AM
ic. USDM 3rd gens have an electronic solenoid that flips a lock out of the way when the key is "on" and the brake lights are lit. otherwise you can't even push the button on the shift lever... and then of course you still have to push the button to move it. my control box for that broke so i had to use the emergency release every time i wanted to go anywhere.
shilov
Feb 19, 2024 09:40 PM
Gingerheadman
Oct 1, 2015 05:11 PM
msellas
Sep 23, 2015 09:16 PM
ajahearn
Sep 19, 2015 03:03 PM
rnb754
Sep 14, 2015 11:39 PM
