Gas mileage
#42
No that was str8 through, I didn't lift off the throttle at all, it just kinda jerked into second gear
#47
#50
good luck finding a VE to get a tranny from. often times there are none at the JY near me, tho you're lucky it's a/t and not m/t, cuz i've only ever seen 1 VE5 at the JY near me. but i guess it's cheaper than getting it rebuilt. WORST CASE scenario you can use a 4th gen tranny and just swap the bellhousing from your VE tranny and use a non-LSD driverside axle (may be the same as a 4th gen axle, but not 100% sure). If you do that you might need to get the diff bearing preload adjusted by a tranny shop, but that's still cheaper than a full rebuild. [Aaron92se is running a VE auto tranny on a VQ engine so it will work in the reverse as well as long as you swap the bellhousing.]
#51
#52
Back with ma update Well I filled up this supposingly 18.1 gallon tank although I only got 15 gallons in their and it was above the "F", anyhow after I damm near empty out my gask tank it was reading 260 miles my calculation 260/15= 17.3 miles per gallon and I know thats not efficient at all, but I also notice that when I'm crusing at 70 the RPM is at about 3200, and that I believe is the problem(transmission failing)
#53
#55
#56
well I do have 17" wheels on ma car I was gunna put the stocks back on soon and see what happens
#57
That doesn't sound right to me. My max is within 75 MPH when I reach 2500 RPM and near or on 85 MPH when it's at 3000 RPM.
But I do get around 12-15 MPG most likely due to an exhaust leak and a bad O2 sensor (which I will fix next week). Don't know if running the car with a bad exhaust system would make a big difference.
EDIT: Just noticed that biggz has a VE engine while I have a VG. So my info won't be that helpful
![sadpace](https://maxima.org/forums/images/smilies/sadpace.gif)
#58
EDIT: Just noticed that biggz has a VE engine while I have a VG. So my info won't be that helpful![sadpace](https://maxima.org/forums/images/smilies/sadpace.gif)
#59
on my 90 maxx, i always keep the power/comfort switch in comfort mode( i want the best MPG possible). however ive noticed that when i start the car only the power light lights up for a second or two. my comfort light doesnt do this, and never turns on, even when its depressed. can anyone tell me if this means anything? thanks!
![Smilie](https://maxima.org/forums/images/smilies/smile.gif)
#61
It's just the TCM initializing when the car starts up. When you put the key in the ON position and the P is lit for a couple of seconds and goes away, it shows that everyting regrading the TCU and transmission is ok. But if the P light were to blink constantly, then there's a problem (electrically, it will not tell you of a mechanical problem).
#62
#63
Mine gets 20mpg AT BEST, on HIGHWAY too. Its the SE Version btw. ((White speedo gauges that go up to 145mph))
This has the VE30DE engine right? or am I wrong?
#64
Yea you have the VE. (EDIT: I saw your craigslist and from the outside it looks like you have a GXE. Are you sure you have an SE?)
Well right after changing the O2 weeks after my last post the mileage went up to around 21 MPG on my last trip. I still got the exhaust leak which I haven't fixed yet cause the rear manifold is warped.
#65
06-06-2017 02:01 PM
