where to get front hubs
Old Nov 12, 2009 | 01:34 PM
Midnight Racer's Avatar
I need a new one for the driver's side front and can't seem to find one and my last resort would be the dealer but does anyone know any other places that sell them
Old Nov 12, 2009 | 01:44 PM
DanNY's Avatar
Ad·min·is·tra·tor
buy the entire spindle from a junk yard.
Old Nov 12, 2009 | 10:21 PM
CMax03's Avatar
Try NAPA they have almost everything, or get the hub from the junkyard and use NAPA to freshen it up with a new bearing!
Old Nov 13, 2009 | 12:24 AM
autobotguy's Avatar
3rd gen wheel hubs are only going to be found in a junk yard. No one sells them new. Perhaps you can take a gander at the sales section of this forum? Maybe someone parting out their Max will sell their wheel hubs to you.
When I replaced my drivers side hub (bearing worn to the point it ruined the hub) I went to a local junk yard and got a decent hub for $28.
Old Nov 13, 2009 | 02:48 PM
1993-VG30E-GXE's Avatar
How did that happen? It wore to the point the bearing outer was spinning in the hub?
Old Nov 13, 2009 | 05:42 PM
Matt93SE's Avatar
STFU n00b!
When the bearings go, they almost always ruin the wheel hub. ANY time you replace a front bearing on a Maxima, you need to replace the hub as well.
Every time I (or a customer) tried to cheap out and not replace it, they wound up replacing the bearing again AND the hub in short order.
Old Nov 14, 2009 | 09:55 AM
Mysticcal's Avatar
Same with me. buy one from a JY. or car-part.com. be careful though. VG and VEs don't match up. I've been going through hell because I cheaped out.
You can also get a new wheel hub on Courtesy Nissan for ~$130
Old Nov 19, 2009 | 05:12 PM
Can you guys tell me what exactly happens to the hubs. Matt are you saying, when the bearing fails in a catastrophic way, it damages the hub immediately or not even catastrophic, if the bearing is broken, and your driving around on it and it's noisy, it's doing the damage then. Even if the bearing were NOT damaged, but you remove the hub from the working bearing, is it the removing of it that scratches the hub and renders it useless or something?
I read the service manual last night for the fronts. It appears you press the bearing INTO the knuckle. Then you press the hub INTO the middle of the bearing right?
For the rears, the whole assembly needs to be replaced.
Old Nov 20, 2009 | 09:06 AM
Mysticcal's Avatar
When a bearing fails it heats to extreme heats and warps the shaft of the hub.
Also a failed bearing will cause a wheel to not remain straight causing metal wear when rubbing at odd angles.
wyobbagy
Jan 3, 2023 12:03 PM
alahjahwan09
18
Sep 21, 2015 09:12 PM
Hdnseek
Sep 9, 2015 05:55 AM
jfl330
Sep 4, 2015 01:44 PM
maximusrising
Sep 2, 2015 09:55 AM
