Fog light modification
I would like to go HID on my fogs at 3k when I mount my newly acquired fogs. Has anyone done this and is it plug and play or are there modifications to the housing that will need to happen?
Any advice or pictures would be appreciated, I didn't see anything in the archives.
Are they OEM foglights that you acquired? You more than likely will have to fab something up. You'll definitely need a spot to mount the ballast and make sure its a dry spot too.
They are, I actually bought some on Ebay as well that were new but turned out to be smaller than what is on there already. I would prefer to keep it OEM so I will probably just clean up the ones I just bought off of here.
What size bulb did you go with? Looks like H3 would be proper but haven't gotten that far yet.
yea the h3 hid bulb will have a long base where you have to cut the rear hosuing, and for the ballast i mounted it in the cornering lights. These HID fogs makes driving at night even better and has no glare because of the shield.
I'm thinking of going 3000k (keep in mind guys the K is not for "thousands" is for degrees Kalvin) when I add fogs to my 95, I've been real lazy but I think the 3000k would look good considering I have 4300k headlights and a dark blue car. I didnt care for the yellow at first but it grew on me after seeing the IS300, QX4, and even the ES300 but not really. All yellow lights are a different story, thats just plain rice.
I agree, my new HIDs are 4300k and I have clear corners but thought that the 3000k in the fogs would add some WOW factor.
Mine is white right now but will probably be changing colors soon.
Did you leave the reflector part inside the glass housing?
Just as you mentioned it, the H3 bulb fit perfectly. I ended up cliping the metal retainer in half so it would go around the base as it is a little wider and taped it back together. I will post pictures later.
glade to hear that u didn't have much problems with the bulbs.
well a picture would help cause we can't really tell because it is not stock and the bulb might be too long.
The Frye
Sep 2, 2021 11:03 AM
fastcarny
Oct 6, 2015 10:42 AM
Maxima30
Sep 7, 2015 06:13 PM
