headlights?
Old Apr 5, 2010 | 02:48 PM
  #81
richard_85zxt's Avatar
not pre 87, I have a front end conversion on my 85 and then have my 89.Might still work though. I haven't look into it too seriously yet because when I do, I look into every aspect of it, right now my research has been suspension related, and as of right now I'm working on roll centers and unsprung weight. I'll either need to do the research and understand EVERY aspect of it, or find someone who knows enough that I can just find a way to mount it and call it good, lol.
Old Apr 5, 2010 | 03:35 PM
  #82
CapedCadaver's Avatar
Call me Wookiee Goldberg
it won't.. the housings are different. it might be close (maybe even as close as putting e36's in a 3rd gen) but there'd be gaps and stuff i think. i dunno, it's worth a shot tho, to go to a junkyard and try to put pre-87 headlights on a 87+ car.
Old Apr 5, 2010 | 04:19 PM
  #83
I know they won't fit directly, just thinking a generic axb size like what you got.
Old Apr 6, 2010 | 09:58 AM
  #84
Teslette's Avatar
As you guys are on to E36's, do you have any faith in fitting these headlamps?
http://www.europeanautosource.com/pr...oducts_id=1592
They're fairly cheap, and do have clear lenses. And as I've understood, you're able to swap the lenses with Maxima ones (same base size, different curving?)?
-Tor
Old Apr 7, 2010 | 08:03 PM
  #85
newbi_maxi's Avatar
yea it does actually. kinda makes me wish i knew about them for my z
anyways, if you do a projector retro, it's best to use the clear-glass'd Ebay headlights. the clear glass ones are ONLY good for retrofits tho, they are worthless if used with just a plain bulb. be super patient with the glue also.. better to be patient than to break the glass.
yea i was thinkin bout gettin those jdm or euro chrome headlights then doing the projector retro
Old Apr 7, 2010 | 08:10 PM
  #86
yeah.. hopefully the bulb hole is the right size to accomodate the mini-projectors nalc was talking about. if so then it would be as simple as baking the headlight to pull the glass off, putting the projector in and making sure it's level, then putting the glass back on.
Old Apr 8, 2010 | 11:55 AM
  #87
nalc's Avatar
It should fit 9004.
Old Apr 8, 2010 | 12:07 PM
  #88
kzoosho's Avatar
Originally Posted by nalc
It should fit 9004.
Nalc those minis are D1S not D1. Im sure you know what D1S is bro.
Old Apr 8, 2010 | 01:01 PM
  #89
nalc's Avatar
No, they're not D1S. There's a ton of info on them over on HIDP. theretrofitsource had them designed in China.
It's a small bi-xenon projector, with a long threaded bulb holder. The threaded section goes through the normal opening in the factory reflector headlight, and then is tightened with a large nut on the back. Then you just pop in a H1 kit bulb and it's good to go.
http://store.theretrofitsource.com/p...06fc87cae155ec
IIRC, they've been proven to fit H7, 9007 (same as 9004), 9006, H4, and a couple other common sizes.
Old Apr 8, 2010 | 01:54 PM
  #90
kzoosho's Avatar
Crap i dont know why i was thinking d1 wen i seen h1. i am thinking about getting a set to see how they do.
Old Apr 8, 2010 | 03:45 PM
  #91
nalc's Avatar
You're on HIDPlanet right?
There are a bunch of output pics... they blow away TSX, E55, E46, Murano, etc. The only projectors that are as bright as them are TL, FX, and RX330.
Old Apr 8, 2010 | 03:55 PM
  #92
kzoosho's Avatar
i was on the planet before you did your first retro, check my join date lol. i have low posts there since i usually read and dont post. Also i never like the tsx ( even tho folks swear they are god), the e55's are great entry bixenons and high beam cant be beat, the e46 well i don't see how they used that garbage, the murano is a great projector. The others i personally have and i have had alot of others.
Old Apr 8, 2010 | 05:35 PM
  #93
y'all mfkrs are tempting me to do minis on my z and put the e55's in my bro's currently-halogen 6th gen (if the bixenons will bolt into the halogen housing just like stock)
Old Apr 8, 2010 | 09:54 PM
  #94
nalc's Avatar
I thought you were, but I wasn't sure. That really good JVX thread with all of the pics has the mini H1s. They look pretty similar to FX.
I am actually kinda impressed with E55s. They get trash talked a lot, but they have great center intensity, just lacking some width.
My current retrofit is going to be RS6, which are very similar to E55s.
Old Apr 10, 2010 | 11:42 AM
  #95
newbi_maxi's Avatar
lol...thats wat im hoping it would be like
Old Apr 17, 2010 | 03:38 PM
  #96
kzoosho's Avatar
Im using rs6 projectors as fogs lol.
Old Apr 17, 2010 | 07:38 PM
  #97
Garf's Avatar
Go to ddmtuning.com for e36 headlights, get either the DJ autos or the Depo's. they run you 100$ plus shipping, and they have glass lenses w/ proper projectors, lots of the guys on bimmerforums are using them with great results. They also have removable glass to make it easier to put on wade covers.
Old Apr 22, 2010 | 07:12 PM
  #98
kzoosho's Avatar
Ok so i got the minis man. Here are few pics i snapped today.
Old Apr 22, 2010 | 08:39 PM
  #99
nalc's Avatar
Very nice. Do they fight in the high beam reflector as well?
Old Apr 23, 2010 | 08:59 AM
  #100
kzoosho's Avatar
They do not. I am cutting the reflector to sit it a little farther back. Its about 1.5 inches to long to fit in the high beam slot.
Old Apr 26, 2010 | 09:38 AM
  #101
newbi_maxi's Avatar
are the projectors in the e36 or just the regular headlights from the maxima???
Old Apr 26, 2010 | 07:01 PM
  #102
kzoosho's Avatar
Those are actually from a 97 maxima but i have only reto'd the clear ebay headlights
Old May 1, 2010 | 02:06 PM
  #103
shiloh51933's Avatar
Unfortunately nobody offers a custom fit projection headlamps for our 3rd generations it seems and you'll have to fabricate yourself. A friend of mine who is a long term member here installed the clear Euros and I thought they
were cool but I'd rather hook up some projections myself, not cause I give a
**** bout oncoming drivers though. You can always install some factory or
after market fog lights if your looking for extra light for style or light reasons.
I installed after market led style fog lamps in about the same location as the
factory lamps and people check them all the time. They look like the new Audi or Mercedes led parking lights, they look tight at dusk with my parking
lights company.
Old May 4, 2010 | 04:26 PM
  #104
kzoosho's Avatar
lights company.
A few members offer projector headlights
doctorpullit
Oct 28, 2019 10:58 PM
trsandrew
Apr 8, 2016 06:45 PM
knight_yyz
Nov 1, 2015 01:34 PM
trsandrew
Oct 25, 2015 02:47 PM
Noela
Sep 26, 2015 08:22 AM
