New wheel and tire fitment
Swapping rear hubs is caaaaake.
pull wheel, caliper, rotor, undo dust cap, remove nut- 32mm IIRC- slide off. clean old grease off. apply layer of new grease. install "new" hub. torque to spec (it's in the FSM). reassemble brakes. done.
it's a 5-10 min job once you get the wheels off.
Do you have to use a socket on the hub nut? I have a 36mm that I use on my axle bolts, but I know I don't have a 32mm.
Can anyone varify the the hub nut size? How about the tq spec? I'll check the haynes manual...I don't have the 3rd gen FSM.
The wheels and brakes are already off on the rear. I left it on stands last night and drove my jeep today. I think when I take the dust shields off I am just going to leave them off.
i think it's a 30mm... cuz i remember when i took them off the parts car recently i used a 32mm because i had left my 30mm at my garage. but at that size it was still enough to keep from rounding it off.
www.nicoclub.com/FSM
I'll probably just buy a 30mm on the way home tonight, and take it back if it does not fit. I was just trying to save myself some driving since it would be a half an hour round trip to go get the socket after I take the nut off, but I drive right past it after I get off work. I looked up the hub nut on the advanced auto site and it does not say the size, and they do not have one in stock for 50 miles around me.
Also as for rear hub nut size does it matter if you have disc or drum brakes because I have disc and I am not sure what your parts car is caped.
I have a pair of 20mm stud in spacers if you want them. Made by Crow Auto. Might be more than you need.
Shoot me an email if you're interested: lrdrandall at yahoo.com
If you post in this thread, I'll probably never see it.
^^^I can't use the stud in ones but thanks.
So here are some pictures of what I have been working.
Here are a few pictures of the rear fenders before I rolled them.
Here are a few pictures while I was rolling them.
here is one of the stock rear studs I pulled.
here is the hub I took off of the car, and the one that I took off of my extra suspension I had.
Here is a picture after I took the dust shields off. I put the bolts back on to hold caliper bracket on...don't worry.
Here is why I need to roll my fenders/get spacers and studs, and I cannot use stud in spacers.
well technically, Kics-brand 10mm spacers would work so long as you cut the studs to fit flush after installation.. but they are probably $$$. note the "flat" nuts.. i'm not sure i'd trust them for how many threads they engage, vs a stock lugnut.
I don't want to deal with cutting the studs. As for the $$ side, they are about the same price as buying a hubcentric spacer and nismos studs (which I have already done). The studs should be here Monday. Hopefully the spacers will get here next week too, and I will post some pictures with the wheels on.
those are z31 rear rotors aren't they?
anyways, one thing to be sure of is that your spare hub has an ABS sensor ring on it, or if not, whether one can be transferred from the messed up one.
the spare did have the abs ring on it so I am good there. Oh, and you were right, the hub nuts were 30mm on both of my sets of rear suspension. The only difference I noticed between my two suspension set ups (I have a spare because I wanted the longer caliper brackets so I can run the Z31 rotors, so I just bought everything from the junkyard) is that the the center or the dust shields had different shapes in the ring around the 4 bolts. One set up was a circle and the other was in more of a star shape.
I finally got around to taking a few pictures.
stock v. 60mm nismo stud
here is how I put the studs in. I put a lug nut on the stud to the left of the one I was trying to install, then put a wrench on that to prevent the hub from spinning while installing the longer stud.
studs installed
spacer on top of new studs
Here is the car that night
studs installed
