Replace Manifold(s)? . . .or OBX headers?
Old Apr 18, 2012 | 06:43 PM
  #81
krashkid0305's Avatar
just bought OBX headers. can some1 please tell me what size and thread the studs are? think i need to replace some and was going to switch them all to grade 8 bolts anyways. courtsey parts lists the studs for $3.50ish ea and doesnt say what size they are. dorman lists M10x1.50 for all nissan so idk if thats the upgraded size or whats factory for a VG
Old Apr 18, 2012 | 07:44 PM
  #82
Chris Gregg's Avatar
Get Off My Lawn
All new oem studs from Nissan are upgraded don't know the grade, but over never heard issues with those who have swapped them out. Contact www.nissanpartsasap.com to see about better pricing.
Old Apr 19, 2012 | 12:39 AM
  #83
maximagician's Avatar
Originally Posted by Infam0usMax
I have a broken stud and it make my car sound like a tractor. . .
were they made weak and low torque spec(13-16 ft lbs.)
because its better to snap a bolt then strip the hole in the aluminum head?
Old Apr 19, 2012 | 12:47 AM
  #84
I did this job for a car that was for sale,it had 2 broken studs in the front
i got one out with an easy out drill bit,but the other one was tougher and
was left alone rather than damage the hole threads
Next time i do this i want to try a VERY small dab of superglue on a 10 mm bolt end held to the broken stud WITHOUT letting any glue seep into the threads
in my experience they just need that intial loosening and then its finger spin
IF the glue dont hold i will try a(once again very very small dab of jb weld or?)
Old Apr 24, 2012 | 11:16 PM
  #85
shiloh51933's Avatar
I finally redid my exhaust!!
I have the new OBX headers/y-pipe and new Megan single inlet dual outlet installed. I had to use an angled drill to remove 8 broken exhaust manifold stud. Anyone who has ever done this knows what you have to do to do this right. I installed all new Nissan brand studs/nuts to hold the headers in place. I got the OBX headers/y-pipe hooked up to a Magna flow high flow cat and resonator pipe and a new Megan Muffler. The only thing I got left to do is make a small modification to the y-pipe flange to cat pipe flange. If I leave the flange the way it is now I'll have intermittent vibrations on the steering rack just above the flange. i believe this issue was mentioned by Somebody in this thread. Other than that it looks and sound bad ***!! I'll get some pics and sound clip as soon as I'm finished.
Putting some rubber on my new rims this week and finishing my suspension.
VQ'ed
69
Aug 27, 2020 12:29 PM
vingodine
45
May 21, 2016 12:46 PM
kenc15
Sep 25, 2015 06:38 AM
ac max 92
Sep 2, 2015 04:23 PM
