long beep
Old May 18, 2011 | 05:42 AM
Kountz430's Avatar
bald aggression est 78
long beep
im hearing a long continuous beep i have the keypad entry system i checked the key pads to make sure that they were'nt jammed and they are not cant i disconnect the control box under the dash
Old May 18, 2011 | 10:12 AM
Hectic's Avatar
You should replace it instead of disconnecting it. In the meantime, you can pull the front door panels and disconnect the beepers.
Old May 20, 2011 | 10:53 AM
Kountz430's Avatar
where are they located by the way? and now im having another problem my alarm randomly goes off this actually started before the continuous beep so after thoroughly freaking out THREE times.i figured i had to start some where
Old May 20, 2011 | 04:06 PM
DMad8724's Avatar
maybe try resetting the code? sounds like youve got some other issues but its worth a shot
Old May 21, 2011 | 04:43 AM
Hectic's Avatar
Remove door panel and it's right there, yellow/orangish metal.
Old Jun 10, 2011 | 08:49 AM
Kountz430's Avatar
i may have finally traced down the problem for the alarm randomly goin off i think the theft warning control unit is bad, i think i might just disconnect it and run an aftermarket alarm with an air horn. i work at a truck stop and barely hear it with the factory horn witch is almost done anyway cause of the alarm. Now is this a common problem? or a once in a blue moon type thing?
Old Jun 10, 2011 | 12:07 PM
maxinout93's Avatar
So if I replace the keyless entry unit thingy on the passenger side under the dash, would that make it work again? It was working when I first bought the car, then it stopped a few years later, and now Im wondering since I will have to replace my driver side door, because of an accident, will the chances of the keyless entry system working again be slim?
Old Jun 10, 2011 | 04:53 PM
Hectic's Avatar
Good idea. A nice 2 way alarm is far superior than stock alarm and keyless entry.
Assuming you know the code to the new control unit, it should work fine. But again, you might just want to look into an aftermarket alarm as well.
MaxLvr21
Oct 17, 2015 12:11 PM
BobTX10
Oct 7, 2015 08:43 AM
maxima297
Sep 30, 2015 03:32 PM
