Mystery squealing
Old May 24, 2011 | 12:26 PM
7mJoe's Avatar
Mystery squealing
I have a squealing coming from the driver's side front wheel area. It varies with speed, and sounds rubbery. Is it possible it could be the wheel bearing? I just swapped out the transmission, but I made sure I torqued the bearing down correctly. It sounded like it was coming from where the axle meets the transmission. The sound is the worst at 5-15mph, and after I've been driving for awhile. Any ideas?
Old May 24, 2011 | 12:31 PM
1991Maxima1991's Avatar
might be your pass side axel, could be the dust shield on ur spindel, i had the same problem once only reason i couldnt hear it after about 20 mph was because the motor and exhaust makes too much noise and it drowns the other noise out, but my problem was a driverside axel...
Old May 24, 2011 | 03:29 PM
7mJoe's Avatar
I'll check that out. I certainly hope I didn't screw anything up. I've put over 5000 miles on it since the swap, and it's just been squealing away since.
Old May 24, 2011 | 09:08 PM
chrome91's Avatar
does it get louder when you go faster? that could be a sign of the wheel bearing
Old May 24, 2011 | 09:41 PM
7mJoe's Avatar
If it is I can't hear it. It comes around after like 10-20min of driving. It's awful when I'm driving slow.
02PearlSE
Oct 7, 2015 02:12 AM
Botnik
Jan 7, 2001 07:32 PM
perlmax90
Dec 6, 2000 03:15 PM
Mike S.
Sep 4, 2000 08:35 PM
bamabob
Aug 25, 2000 10:24 AM
