ypipe install?????
Old Dec 28, 2001 | 08:39 AM
MaDMaX024's Avatar
ypipe install?????
i just need a little info on the installation of a new ypipe. i'm planning on ordering a warpspeed non-mandrel bent y for my max, i just need to know how hard it was to install. do i need an impact wrench or can it be done with sockets? is there anything else i'd need to buy that doesnt come with the pipe? any tips or tricks? approximatley how long should it take to install?
Old Dec 28, 2001 | 12:03 PM
Lordrandall's Avatar
If you are buying from WSP, I think they include all the gaskets you need. Someone correct me if that's wrong.
You can do it with basic tools, but a swivel socket makes it much easier to reach some bolts. Also make sure you SOAK the bolts with WD-40 or stronger the day before you plan your instal. It should make it easier to remove them.
Time depends on your skill, and if you have helpers. Can take anywhere from 1 hour to 6..... hehe
Old Dec 28, 2001 | 12:18 PM
MaDMaX024's Avatar
sweet, that means all i need is a swivel socket.
thanks
Old Dec 28, 2001 | 12:41 PM
SuDZ's Avatar
They do include the gaskets instead of charging you 15 extra for them.
Start a few days ahead with the soaking. Trust me I soaked mine for about three days everyday before hand and it was still tough and mine was on a 98.
SuDZ
Old Dec 28, 2001 | 06:21 PM
MaDMaX024's Avatar
SuDZ
whats the best thing to soak it with? PB Blaster? WD-40? liquid wrench? i figure i'll start a week or so before..
Old Dec 28, 2001 | 08:27 PM
PATRICK94SE's Avatar
I like liquid wrench
Old Dec 29, 2001 | 07:23 PM
Aaron92SE's Avatar
NWP Engineering.com
I used PB for my Y-pipe install. My car has spent it's entire life in Las Vegas where there is no rain or moisture. So, they came off really easy for me after spraying PB on the nuts 10 seconds prior to removal. If your car lives in a wet or salty place...I think it will be very hard. But, penetrating oil definitely works better than WD-40.
Old Dec 29, 2001 | 08:04 PM
flyry110's Avatar
my i suggest LOTS of PB blaster on the bolts. . . . . spend the extra dough and get PB!!!
Old Dec 29, 2001 | 08:33 PM
MaDMaX024's Avatar
will one can be enough? how many bolts will i be soaking? 2 or 3 at the cat, 3 at each manifold..is that it? 9 at the most or are there more?
Old Dec 29, 2001 | 08:41 PM
flyry110's Avatar
1 can should do ya. . they're like 3 or 4 bucks. . .
MaxLife17
Jun 27, 2019 01:37 PM
Excalibur23
Oct 13, 2015 04:33 PM
Max8
Sep 22, 2015 02:53 PM
2kmaximel
Sep 16, 2015 03:19 PM
Johnny9595
Sep 3, 2015 05:18 AM
