Engine misfire/intermittent misfiring
Old May 26, 2012 | 12:54 PM
rvanders37's Avatar
i simply must share what caused my 1993 maxima to missfire it wasn't the injectors which i replaced. it wasn't the wires, plugs, fuel filter fuel pump, airfilter or erg related stuff. it was the single wire off the distributor for the camshaft position sensor. the connector was corroded and green and crumbled when it pulled on it. i simply stripped back some clean wire and crimped a new terminal, plugged it back in and presto! everything is normal again. save yourselves some time and look for this first. the camshaft position sensor wire.
you are all welcome.
Old May 26, 2012 | 01:17 PM
shiloh51933's Avatar
Let's see some pics of your work.
shilov
Feb 19, 2024 09:40 PM
Socalstillen
Sep 20, 2015 11:46 PM
seesole
Sep 14, 2015 12:38 PM
ballerchris510
Sep 11, 2015 05:29 PM
