VG Cooling issues
Old Jul 30, 2012 | 07:07 PM
Tampamaximus's Avatar
VG Cooling issues
Hey guys so far the car is coming along nicely. I have 2 hoses that dont seems to blow clear through and I did have some rust issues in my cooling before any suggestions? help? Do they not open until operating temperature?
Old Jul 30, 2012 | 10:03 PM
maximo018's Avatar
Is there any sign of fluid ever being there? Or does it look bone dry like nothing has passed through it in ages?
Old Aug 2, 2012 | 08:27 PM
Chris Gregg's Avatar
Get Off My Lawn
Coolant lines on intake manifold can be bypassed. Unless you see sub freezing temps regularly, forget it.
Old Aug 2, 2012 | 09:46 PM
7mJoe's Avatar
Probably just really clogged. See if you can get pipe cleaner or some wire or something up there.
Old Aug 4, 2012 | 12:35 PM
Yes I tried putting wire through it and even hooked up a compressor and blasted to no success. Any other suggestions? I just did a lot of work to the max and I kind of want to be **** about getting this rust **** done with in my cooling system.
Old Aug 4, 2012 | 10:41 PM
CMax03's Avatar
Maybe the OP filled it with something!
Old Aug 4, 2012 | 11:02 PM
maximo018's Avatar
Well it as someone else stated it i believe they are just the lines for the manifold cooling. Unless you live somewhere were it gets extremely cold (up north) you don't need it. But if you really want to have it as its suppose to be the trace to the other end and reconnect the cooling system and you should be set.
Old Aug 5, 2012 | 03:05 AM
CMax03's Avatar
You will need to loop the hard line dipple back into something else since it goes to cabin heater!
Old Aug 5, 2012 | 08:20 AM
James92SE's Avatar
2 VE's are better than one!
You need bigger tires
Old Aug 5, 2012 | 09:30 AM
CMax03's Avatar
......and a drop!
Old Aug 5, 2012 | 12:42 PM
maximo018's Avatar
Lol
Old Aug 5, 2012 | 08:38 PM
I swear thats why I never wanna show you guys anything till Im done..
Mar 12, 2020 12:06 AM
conansriver
Nov 18, 2015 02:46 PM
gustavison
Oct 4, 2015 06:50 PM
wingnut2006
Sep 19, 2015 06:13 AM
BrandonCause
Sep 14, 2015 10:41 PM
