General q's and a problem with heat.
Old Jan 7, 2002 | 12:02 PM
200HP4dr
Hello,
My friend has 90 Max, and he has no heat whatsoever. Well, really, sometimes he'll get a little hot air, but then it will all be cool air. His thermostat is about 2 years old, but this problem has recently presented itself. Any suggestions?
Also, what engine does he have? I have seen references to VQ and VE, but have no way to tell which is which.
Thanks,
Chris
Old Jan 7, 2002 | 12:16 PM
Matt93SE's Avatar
STFU n00b!
All 89-91 Maxes have a VG30E (VG) engine.
VE are in 92-94 SE only, and VQ are in all 95 and newer models.
check the coolant level on the car and mskre sure there's enough coolant and there's no air in the system.
once you're sure it's full of coolant, there's a "bleeder valve" bolt right on top of the PCV valve on the intake manifold. remove that screw while the engine is running (and Cold- NOT HOT! : ) and let any air escape.
if that's not the problem, then there's a heater control valve mounted ont he firewall.. it determines how much coolant goes through the header core, and if that's bad, then it may not be opening to let hot water into the core.
Old Jan 8, 2002 | 03:12 AM
200HP4dr
Matt,
Thank you very much for your help. Could you point me to where the heater control valve might be located on the firewall?
Thanks,
Chris
homewrecker
Sep 24, 2015 07:01 PM
ac max 92
Sep 17, 2015 07:35 AM
