Tire to wheel sizes
Old Jan 9, 2002 | 06:38 PM
bored365247's Avatar
Tire to wheel sizes
OK sorry about being a newbie but here it goes. I want to put 17" wheels on a 93 GXE and i was wondering what tire sizes fit with out any rubbing in the tire well or anything like that. I was thinking of getting the Konig Rated R's with 225/45/R17. Not gonna buy just yet but planning for the very near future. I checked that tire size calculator at miata.net but wasnt sure. Thanks
Old Jan 9, 2002 | 06:46 PM
noleafclover's Avatar
Re: Tire to wheel sizes
lol...before you guys yell, i happen to know he did search and asked for help first, it's not always easy to find info when you search and there's too much info out there..
Old Jan 9, 2002 | 10:53 PM
Bman's Avatar
Well, as long as you tried searching There IS a lot of info out there and it's hard to distill sometimes. The Konig Rated R's I found on the internet were all 17x7" size, so I wouldn't go wider than 225/45/17 even though the closest size is 235/45/17 (too wide for a 7" rim).
James92SE got Konig Subzeros on his car with the same tire size a few weeks ago. He's reported no rubbing or any problems yet. The Subzeros have 45mm offset and the Rated Rs (the ones I've seen) have only 40mm, so I think you should be alright there. You can try asking James what he thinks of his setup.
The way our cars are, most of the worry isn't in rubbing the fender, but rubbing the suspension. It might help also if you choose a tire with a narrower cross-section. Go to www.tirerack.com and look at the Yokohama Avid T4/H4. The section width for this tire is greater than other makes/models in the same size. Sometimes this is because of a rim protector or rim guard on the side of the tire. Yes, we are probing the limits with tires this wide, so every bit helps!
Nice rim choice BTW.
Old Jan 10, 2002 | 12:48 AM
yeah thanks. i liked them from the time i went with my friend to go shop for wheels for his truck. I checked out those yokohama's and they dont make them in 225/45/17. I only found two tires that fit on http://www.whalentire.com. BTW this is the cheapest ive seen the rated r's for 130 there at whalen. I like those tires for 100 bucks ill end up getting cheaper ones if i can find them. Dont plan to race much. Thanks for your help
Old Jan 10, 2002 | 10:42 AM
Bman's Avatar
Oh that's good they don't make the Yokohamas because my point was NOT to get those! I bet one of those two tires at Whalentire are the Kumhos. I've heard both good and bad things about them, but they are probably THE best deal in Ultra High Performance tires out there, so I plan on getting Kumhos (when the time is right).
BkGreen97
Apr 2, 2016 05:47 AM
alahjahwan09
18
Sep 21, 2015 09:12 PM
minsbang
Sep 11, 2015 08:48 PM
dcam0326
Sep 8, 2015 11:02 PM
jfl330
Sep 4, 2015 01:44 PM
