Maxima rims size help
Old Mar 6, 2013 | 03:35 PM
TonyJr's Avatar
Do these rims fit perfect on a 3 rd gen? Im buying them for $150 with tires if they fit. Seller said there 17 inch maxima rims.
https://i.imgur.com/l9kQA5A.png
Old Mar 6, 2013 | 03:41 PM
shiloh51933's Avatar
They'll fit...some guys have 19x8 inch rims on there 3rdgens. I went with a 17x8 inch rims with 225/50/17R Toyo Proxes.
Old Mar 6, 2013 | 03:48 PM
TonyJr's Avatar
Thanks. Are these from the 4th gen?
Old Mar 6, 2013 | 05:39 PM
BenStoked's Avatar
Jesus was a Zombie.
yep, 4th gen wheels.
Old Mar 6, 2013 | 07:07 PM
jbbons25's Avatar
Those are actually 16 inch wheels. And yes they'll fit. Think I've seen some with those wheels on the pic thread.
Old Mar 6, 2013 | 07:09 PM
tosheto's Avatar
As stated above. Those wheels are 16". They will fit. They come off 97-99 Maxima SE
Old Mar 7, 2013 | 12:01 AM
CapedCadaver's Avatar
Call me Wookiee Goldberg
rim height isn't what determines fitment anyways... it's width and offset.. unless you are talking about 22+ which start making any tire you'll find have a taller overall height than the stock 25.6". All a "19's" do is force you to run a lower profile than "16's" and everything in between...
Old Mar 7, 2013 | 01:55 AM
TonyJr's Avatar
Thats perfect that this rim is Se because its going on my 92 Se.
Old Mar 7, 2013 | 05:57 AM
I was trying to keep it simple...some people have no idea what offset is.
Old Mar 7, 2013 | 06:03 AM
so I try to educate them, rather than acting like something as important as that doesn't even exist.....
8" width is about as much as you can expect out of a 3rd gen. and then, the offset has to basically be perfect. Anything lower than 25 and you'll probably never get it to fit... higher and you can adjust with spacers if need be.
the fitment chart for z31's is awesome... i don't know of one for 3rd gens, but it should be fairly possible to find out based on people who've had issues with rubbing.. granted tire width (and how much the tires hang out past the edge of the rim) is also something to consider. Just cuz the bare rim fits doesn't mean it will with a tire on it.
http://www.az-zbum.com/information.w...nd.tires.shtml
Old Mar 7, 2013 | 01:01 PM
There 4thgen rims and not much to school on an old 4thgen wheel...
Old Mar 7, 2013 | 01:08 PM
those particular rims fit, yes, we know it, but we only know it because it's a common choice that other people have done so we all happen to know they fit... but like with those Chrysler 300c wheels I had, i tried them, and it didn't work out so well, even tho they were 17x7's, the offset was just too damn low (+22) and they sere rubbing on my fenders.
Meanwhile the 17x7 5.5gen wheels fit just fine... offset of +40-ish.
Old Mar 7, 2013 | 01:14 PM
also i want my old car back. dammit.
Old Mar 7, 2013 | 03:06 PM
James92SE's Avatar
2 VE's are better than one!
I thought you bought a black one the past year or two?
Old Mar 7, 2013 | 03:27 PM
i liked my first one better. I took the black one as a trade. I didn't go shopping for it.
i like the pearl white color much better, don't like having a sunroof, and don't like the leather seats. And the black one's chassis has pops and stuff that my white one didn't.
Old Mar 11, 2013 | 06:45 AM
Richy Rich's Avatar
Any set of 4 fronts from a 350Z / 370Z would work
http://www.finishlinewheels.com/NISS...08/A-62455U78/
7th Gen MAX wheels might work, 19s are 4+
http://www.finishlinewheels.com/NISS...09/A-62512U15/
18" replicas...
http://www.finishlinewheels.com/NISS...9/A-62511U20N/
These 370Z wheels would look great!
http://www.finishlinewheels.com/NISS...09/A-62523U85/
Old Mar 14, 2013 | 03:41 PM
MaximaDrvr's Avatar
I ran 17x8 et25 on my maxima with 255/40/17 (might have been 35) all the way around on my maxima. I did have to roll the fenders to not rub at full compression though.
Old Mar 14, 2013 | 03:57 PM
probably ET25.. i'm not sure if ET35 would fit at 8 inches wide (unless you were running hellafag stretched tires)
Old Mar 17, 2013 | 07:29 AM
TonyJr's Avatar
https://i.imgur.com/nxfdpi9.jpg
Thanks for your inputs just install the rims n it look great. I just need to lower it n paint same color
Old Mar 18, 2013 | 05:44 AM
Matt93SE's Avatar
STFU n00b!
Yup. I've run 17x8 +35 and +25 w/ 245/45/17 on my car without issues. had to roll the rears just a touch, but no pull.
A 235/45/17 fits better and you can run them without rolling the fenders, but the 245 have so noticeably more grip on the track..
Old Mar 18, 2013 | 06:03 AM
Richy Rich's Avatar
Old Mar 18, 2013 | 06:05 AM
Richy Rich's Avatar
Agreed,
when I ran my 97' COBRA wheels on the MAX with the stock 245s, cleared completely. I think Ford Stang wheels are +35.
Old Mar 20, 2013 | 05:11 PM
MaximaDrvr's Avatar
Mine were for mustang wheels. The are definitely et25.
I wasn't sure if I was a 255/35/17 or a 255/40/17 that I was running for tires.
I just know that they were expensive, and the car could turn like a miata.
Mine was fully gutted, and weighed under 2400lbs IIRC
Old Mar 20, 2013 | 05:34 PM
so with the 245's, did the +35 require rolling as well, or only the +25?
Old Mar 20, 2013 | 06:10 PM
Richy Rich's Avatar
You know,
This is one where I can say... "GEEZ! I never took a picture!!!"
- let me remember...
here's an article I wrote back in 02' http://4dsc.com/articles/suspension/...g_wheels.shtml
No rolling the fender, I do remember rubbing slightly with my Eibach set-up / 4 people in the car... never tried the stang wheels with the INTRAX.
What I do remember is; the handling was terrible... felt like I was driving a steam roller - turn in was suffering and the weight was very anti-performance.
Note: the mustang wheels do not have the same hubcenter radius, BIGGER than the nissan... so a set of those plastic sizers would be needed to ensure proper centric setting.
Here's someone else car with the same size/offset stang wheel...
This looks like a 235, better...
Old Mar 21, 2013 | 09:25 AM
mine are the ones like on the black car. I just have them sitting around, haven't put tires on them yet. I guess i'll throw 235's on and see what shakes loose
Old Mar 21, 2013 | 05:46 PM
btw TonyJr go check your "WTB" thread...
Old Mar 21, 2013 | 06:33 PM
TonyJr's Avatar
I inbox you
Old Mar 25, 2013 | 11:45 AM
MaximaDrvr's Avatar
Mustang wheels- 17x8 et25
Eibach drop
255/40/17 tires
Slight fender roll so it didn't rub in turns/bounces
Car was gutted, and ran hard. Hood scoop was functional.
Old Mar 25, 2013 | 07:09 PM
2Legal4Me's Avatar
Whats the offset on the wheels you are using? I have 2 sets of mesh wheels ones from a crown victoria high offset 12mm or so and the other is lsc lincoln mark 7 30mm and I want to run wider than 205/55r16 maybe 215 or 225 if possible.
ah2002
Mar 9, 2016 01:42 PM
tothemax2003
Wheels/Tires
Sep 1, 2015 06:01 AM
criminalslang810
Aug 16, 2015 08:12 AM
Max8
Aug 15, 2015 07:06 AM
follyburr
Aug 12, 2015 08:57 PM
