Faded Side Moldings?
Old Jan 16, 2002 | 04:30 PM
SnoopyZ
Does anybody have a quick fix for this problem? My 91 Maxima (white) has side moldings that are faded and look yellow. It didn't use to be so bad, but now every time I wash the car it looks dirty still because of the moldings. Does anybody know a cheap way to paint or remedy this problem? I have tried many cleaner waxes and products. Any help would be great. Thanks
- SnoopyZ
Old Jan 16, 2002 | 04:34 PM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
1) remove them and leave off
2) remove them, sand down, repaint and reattach
Old Jan 16, 2002 | 04:35 PM
SnoopyZ
What should I paint them with? I am not too familiar with do it yourself painting products. Thanks
Old Jan 16, 2002 | 04:41 PM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
check out http://www.paintscratch.com/ . people have used their products with great success. if you've never painted before i wouldn't suggest making that your first project. Get some help from a friend or something.
you can check out http://maxima.cardomain.com/id/chris91se to see pics of my car with the moldings removed...
Old Jan 17, 2002 | 06:32 AM
Eric92SE's Avatar
My yellowed side moldings are also driving me nuts. As far as removing them goes, what technique did you use? Did you just gently pry them off? Also, as far as looks go, what is everyone's opinion on removing the moldings?
Old Jan 17, 2002 | 06:37 AM
SEguy182's Avatar
do a search this has been talked about a lot, the search will tell u the best ways and products to use.
Old Jan 17, 2002 | 06:43 AM
thebull's Avatar
Re: Faded Side Moldings?
mine were doing the same a little last year. alot of people remove them, but i just dont think it looks right without them. i taped them off (no need to remove)and sanded all the paint off and got them real smooth. got some paint from autozone that matched(check your paint code to get exact match and then look in the books they have at the store to match it up). then just primered the moldings and put a few coats of paint on. and clear coated them. they came out perfect looks like brand new. match up nice with the stock paint.
Old Jan 17, 2002 | 07:06 AM
whitymax's Avatar
you can see mine too
i think the car looks pretty good without the side moldings i have a few pics of my car but i can't find them on the website. they were taken during the huge meet we had in liburty state park. anyone know where to find those links? i want to print one of those pics out. huge
thanks
Patrick
Old Jan 17, 2002 | 12:02 PM
Bman's Avatar
Re: Re: Faded Side Moldings?
Oh good! I plan to do the same when the weather gets warmer.
Old Jan 17, 2002 | 12:18 PM
maximum3rdgen's Avatar
i think it looks good without side moldings. it would look better if you were to fill in the indent too after you take em off, itd look alot smoother......only need some body filler right?
Old Jan 17, 2002 | 12:32 PM
Bman's Avatar
Depends how deep the indent is, since I'm fairly sure it's not good to use Bondo over a certain thickness (it gets fragile). It might tell you how thick you can apply it on the box or in a book about bodywork (or maybe even those Chilton manuals?).
Old Jan 17, 2002 | 03:17 PM
yea i know that sometimes it can get to thick and the paint wont adhere and brittle and stuff but if that was the case u could just get steel plates and cut em to te the size of the indent then weld em in sand down lil body filler and presto well not really but u kinda get the idea
Old Jan 17, 2002 | 03:51 PM
thebull's Avatar
yeah, i would stay away from using bondo on stuff like that. body filler is only used to smooth the body out a little when removing a dent or something, like 1/8" imperfections. if you apply it think its gonna crack and not turn out well. even if you do get it to be smooth body filler tends to break down after 5 years(well, atleast according to import tuner)
Old Jan 18, 2002 | 11:07 AM
Pit5Bull's Avatar
I took them off and don't miss them...
Check out my website, I left some detailed info on removing them on there for anybody that's thinking about removing theirs.
I think my car looks WAY better without them. I just recently got around to getting the last of the adhesive off the doors, and it looks great!
It will probably take just as long to remove them as it does to paint them, so you'll have to decide which way you like the best. Have fun deciding!
peace2u
user 11122324
42
Jul 18, 2022 03:35 PM
aw11power
Oct 10, 2021 04:57 AM
sliptap
Sep 30, 2015 05:57 AM
salty318
Sep 28, 2015 07:22 PM
Noela
Sep 26, 2015 08:22 AM
