Help! 93 maxima trans problem!!
Old Apr 20, 2015 | 01:58 PM
Matt77's Avatar
Hey guys, I have 93 maxima that is having a weird trans prob or could maybe be a sensor.. Idk but it'll go in 1st, 2nd and then RPMs go up but I can feel that it's still grabbing because I can let off then back on and it still has a little grab which I'm guess that's 3rd.. Can anyone please help me on this
Thanks!
Old Apr 20, 2015 | 04:46 PM
chrome91's Avatar
is it a GXE? GXE auto trans are notorious for failing early because of how weak they are. for starters check your fluid level
Old Apr 20, 2015 | 06:24 PM
maxinout93's Avatar
If its a GXE automatic, It may be on the way out, id start looking for a spare if I were you if the fluid level is fine and there are no leaks. You may be on borrowed time.
Old Apr 20, 2015 | 09:46 PM
Matt77's Avatar
Not to sure if it's a GXE I'll find that out though, thanks guys and fluid is good
Old Apr 21, 2015 | 01:32 AM
maxinout93's Avatar
the gxe has the single ohc engine, 125mph speedometer, usually chrome body, door mouldings. VS the 93 SE has the more powerful DOHC engine, 145mph speedometer, white face cluster, sawblade rims, black body side molding, weatherstriping, usually tranny lasts longer than the gxe to my knowledge.
Old Apr 21, 2015 | 04:59 AM
Matt77's Avatar
Ah yeah it's a sohc and the 125 mph :/ but it's the edition with Bose sound system sunroof leather electric seats and has the black side moldings, idk if that's a better edition that would maybe have a better tranny or they just came like that
Old Apr 21, 2015 | 05:05 AM
Matt77's Avatar
But it's all sounding like the tranny is going,an here I was hoping it was just a sensor or the ECU lol
Old Apr 21, 2015 | 08:33 AM
Darkwing48's Avatar
Sawblade rims is an SE Trim thing.
SOHC SEs are only between 89-91.
Old Apr 21, 2015 | 10:14 AM
ac max 92's Avatar
Your trans. Is an RE4F02A. Could also be shift solonoids or just the valve body. Before you jump to conclusions check with a good tranny shop thats not going to take you for a ride and maybe you can still get some more years outta your gears lol. Hows the fluid? When was the last time it was changed? Is it a brownish colour or a pinkish to red colour? You could also do a fluid change to see if that helps. It's just a simple drain and fill with no pan to drop or filter to change. If you decide to change the fluid drive it for a few weeks then repeat the drain and fill process as there will still be dirty fluid in the torque converter. DO NOT do a flush just a couple drain and fills will help clean it up. Also adding an external cooler can help a great deal too. It may not help so much now unless your trans. is still in good working order but if your tranny does need some work or you get it rebuilt or swapped then add an external cooler for what theyre worth to help with preventative maintenance but in the meantime take it to a good tranny shop get their opinion and change the fluid.
Old Apr 21, 2015 | 11:25 AM
chrome91's Avatar
get it checked out by a tranny shop, its just that the GXE trans is common to fail because its made for 4 cylinder engines and with the higher torque of VG30 the trans fails around 150,000km-200,000km usually. i got 430,000km out of my GXE before the forward clutches started slipping a bit so who knows
Old Apr 21, 2015 | 06:18 PM
maxinout93's Avatar
Right, I think my 93 gxe started to slip between 1st and 2nd gear, then fluid started to get darker, gave me about 3 or 4 months notice before it finially flew while I was on the Interstate, had about 225K miles. Found a cheap one for $300 though
Old Apr 22, 2015 | 06:19 AM
Ray229Harris's Avatar
What do you mean slip between 1st and 2nd? I'm having some acceleration/shifting problems with my car and i haven't figured out why yet.
Old Apr 22, 2015 | 07:59 AM
ac max 92's Avatar
Check your fluid level and change the fluid if it's a brownish colour. See if that helps then check back.
Old Apr 28, 2015 | 09:12 AM
Gonna repeat the process in a week or two and check back again.
Lakersallday24
Nov 7, 2024 07:31 PM
Samedi
Aug 13, 2015 04:05 PM
ef9
Aug 13, 2015 01:19 AM
Hawkeye61
Aug 12, 2015 06:45 PM
