vg ignition coil
Old 06-04-2015, 05:38 PM
ac max 92's Avatar
vg ignition coil
Out of the 2 wires to the coil which is positive and which is negative? I believe one is solid green and one is white with green stripe.
ac max 92 is offline
Old 06-04-2015, 07:33 PM
CMax03's Avatar
Not home to see the FSM but check it with the ignition on...with a test light or VOM...
CMax03 is offline
Old 06-05-2015, 09:59 AM
ac max 92's Avatar
I had a funny feeling I was gonna get that answer lol. I haven't been home yet so I was just seeing if anyone knew off hand but I can take the test light to it when I get home. Not sure if you got my pm CMax but I was just curious did you pair your coil up with an aftermarket ignitor/ignition module or did you leave the stock one in with no problems?
Old 06-05-2015, 10:07 AM
CMax03's Avatar
QUOTE=ac max 92;9051333]I had a funny feeling I was gonna get that answer lol. I haven't been home yet so I was just seeing if anyone knew off hand but I can take the test light to it when I get home. Not sure if you got my pm CMax but I was just curious did you pair your coil up with an aftermarket ignitor/ignition module or did you leave the stock one in with no problems?[/QUOTE]
Just used OEM systems or both D21 and 3rd Gen...I did answer the PM....
CMax03 is offline
Old 06-08-2015, 09:45 AM
ac max 92's Avatar
For those that may want to know if they go with a different coil green and white is positive and solid green is negative atleast on the vg's anyway. CMax i got the coil in place where the oem one was mounted. I just had to make a custom bracket so the coil wasn't sitting on an angle like the oem one was. Thanks again for your help
jmlee44
10-02-2022 02:13 PM
TallTom
50
07-08-2022 09:54 AM
AaronL
08-08-2020 10:31 AM
dshinn
09-26-2015 08:07 PM
zmcneely13
09-26-2015 02:26 PM
Quick Reply: vg ignition coil
