Eibachs installed
Old Feb 28, 2016 | 01:43 PM
Tiniform's Avatar
Eibachs installed
Before
After
I am not liking how it turned out. It sits 3/4" higher than it did before. It's still only the rear that installed so i expect it will sit higher when the front is completed. Hopefully it grows on me but right now i am not so sure
Old Feb 28, 2016 | 02:30 PM
ac max 92's Avatar
Thats pretty strange. You say it actually sits higher with the eibach's? Once the fronts and rears ard done it should sit just over an inch lower i believe the drop is 1.2 " all around.
Old Feb 28, 2016 | 02:45 PM
James92SE's Avatar
2 VE's are better than one!
It doesn't nearly look 3/4" higher to me? In fact it looks largely the same to me, but is hard to tell since it's not the same camera angle
Old Feb 28, 2016 | 03:04 PM
imported_Nismo_max's Avatar
wow i envy you guy's rear quarter panels. so clean, no sign of surface rust. i need me a southern ve in good shape. asap..lol
Old Feb 28, 2016 | 04:21 PM
James92SE's Avatar
Get James_EastTX to cut you out the quarter panels on his parts car. Then weld them into your car
Old Feb 28, 2016 | 05:16 PM
DanNY's Avatar
Ad·min·is·tra·tor
might need some time to settle
Old Feb 28, 2016 | 06:00 PM
Tiniform's Avatar
I am hoping it will settle because the springs look to be in almost brand new shape. The springs I replaced were 2" drop and I really loved the way the car sat then. I l knew it would sit higher on the eibachs but not as high. The other factor also is the ST rear sway bar which I installed more than likely contributed to the height. I'll try and do the fronts this weekend and see how it turns out. In any case, I am way too deep into it to back out now especially since I've already offered the old springs to my buddy.
Old Feb 29, 2016 | 04:49 AM
ac max 92's Avatar
I wouldnt worry too much. Im sure once everything is installed and settled after a week or so of driving im sure it'll work out for the best without disapointment. The eibach's over your previous springs should only sit about 0.8" higher.
Old Feb 29, 2016 | 07:36 AM
James92SE's Avatar
Tiniform, can you take a picture of the passenger side rear with the Eibach from the same angle as your "before" picture?
Old Feb 29, 2016 | 01:43 PM
Tiniform's Avatar
After pic from passenger side
This one illustrates how much higher it is compared to the front
Old Feb 29, 2016 | 02:53 PM
James92SE's Avatar
It's amazing two people can look at the same thing and have completely different thoughts on it. Your car actually looks level to me now - as opposed to 3rd gens usually looking lower in the back with lowering springs (and even in stock form in a lot of cases).
Old Feb 29, 2016 | 04:57 PM
Tiniform's Avatar
I don't think the pics actually shows how much higher the back is. Now, it is quite possible the increase in height seems exaggerated because the front is so low, when the fronts are installed it may be more "pleasing" on the eye. I must say though, the rear feels a lot stiffer. It would be fun to drive if the roads here in Florida were more exciting.
Old Mar 1, 2016 | 05:16 AM
DanNY's Avatar
Ad·min·is·tra·tor
get like 2 12" subs in a massive box and a few amps to run them...that'll fix it.
Old Mar 1, 2016 | 07:57 AM
Tiniform's Avatar
That will definitely help but the stereo doesn't go back in for a little while. I am going to have to grow to like it I guess.
traxtar944's Avatar
Would be lost w/out the org
That looks level, and is the same ride height as my 3rd gen with Eibach/Tokikos. The B&G springs I had before were about 1" lower, but a MUCH stiffer ride... to the point it was not that fun to drive.
Old Mar 1, 2016 | 12:31 PM
Geordie's Avatar
Seems level to me, and looks great.
Quite jealous of your bodykit.
Old Mar 1, 2016 | 02:49 PM
Tiniform's Avatar
Geordie, like most of the other upgrades, I was fortunate to have found the kit at a great price nib from a former org member.
Old Mar 1, 2016 | 05:48 PM
TonyJr's Avatar
I have Eibach with koni adjustable shocks
Old Mar 2, 2016 | 03:04 AM
Geordie's Avatar
Your front arches look higher than your rears on that pic. Is it just the angle of the camera?
Old Mar 2, 2016 | 01:29 PM
James92SE's Avatar
It's probably the mobile mechanic shop he keeps in the trunk. Right Tony?
Old Mar 2, 2016 | 03:20 PM
Tiniform's Avatar
Lol
Old Mar 2, 2016 | 07:26 PM
madmax123's Avatar
Hilarious only cause ive seen the stuff in tonys trunk
2014Maxima
Sep 9, 2016 10:19 AM
tallblazer124
Mar 14, 2016 08:39 AM
DeusExMaxima
Mar 4, 2016 02:50 PM
reallywildstuff
Feb 25, 2016 12:10 PM
Maximum Performance
Feb 22, 2016 09:19 AM
