VE engine rear crank bushing
Old Dec 12, 2021 | 03:10 PM
FanaticMadMax's Avatar
Has anyone have any idea if the VE engine of automatic and the VE engine of manual transmission are interchangable, because I got a replacement motor from JDM of Texas and when I redid all the gasket and seals on it, before I am dropping in to replace a blow motor that is from a 5spd and I noticed the back of the crank of the new motor look from the automatic and theres a bearing in it usually with manual has a pilot bearing but I realize i could not put the new pilot bearing in cuz it has a different bearing and I'm trying to remove it and it'll won't move or budge. Anyone had that experience and how you do it. It was almost like its welded or really really stuck in there on the outer circle of the crank.
Old Dec 13, 2021 | 04:07 AM
Reality sucks's Avatar
https://maxima.org/forums/3rd-genera...g-bearing.html
Old Dec 15, 2021 | 02:28 PM
yeah i saw that post but it looks like the VG is easier, but ,mine is definitely not budging and no matter how many time i used a puller its not moving, it looks almost like it's welded since I am trying to dremel it out and still not moving.
Old Dec 17, 2021 | 05:41 PM
Post Up a Pic.. and lets take a Look.
Old Feb 9, 2022 | 07:21 AM
DanNY's Avatar
Ad·min·is·tra·tor
late to the response...you'll need a pilot bearing remover. looks like a gear puller but reversed, there's usually a slide hammer attached to it so you can pull it out.
maxinout93
Jul 15, 2010 02:31 PM
300zmax
26
Mar 23, 2009 08:23 PM
maxitech
Apr 16, 2008 12:20 PM
Duckman540i
Oct 16, 2007 03:11 PM
allen222
May 21, 2005 01:54 PM
