Possible VTC trouble...
ive been hearing ticks from the engine/lower front end area, like really fast ticks (about 4 ticks per second) but the thing thats got me is that it only ticks and idles rough in R, D, 2 and 1. P and N it runs smoothly and no ticks. I thought that the VTCs ticked only when the car is cold and for a short time. Mine ticks mainly when warmed up and in gear. Its a really low volume tick, i can only hear it when im going through a drive thru and im next to a building wall.
Re: Possible VTC trouble...
Unlike other VTC problems, mine ticked ALL THE TIME, warm or cold. I have a 5 speed and even when I was in Neutral, I heard the ticking. I grounded out the VTC, thanks to Craig, and the ticking has stopped. Hasn't ticked since Nov 2000 !!!
I hope you're kidding about losing that much HP.
A few people have said they noticed a very slight decrease in power but not anything more than 1-2 HP or so.
If it did do anything dramatic, I wouldn't have done it to my car (same with many other people I'm sure).
It'll take you all of 10 minutes max and it's completely reversible
procedure is in the how-tos on my page
I should be able to describe the diffference in a few days. I had grounded the VTC's (it didn't work for some reason), and am currently having them replaced with new ones. I'm not sure why they didn't stop ticking when they were grounded, because I had the VTC's diagnosed by 2 different mechanics, one of which was at the Nissan dealership. Either way, I'll post in a few days to describe the difference in driving with busted VTC's and new ones.
Originally posted by Jeff92se
http://www.geocities.com/maximamike/nvcs-bible.html
good writeup Jeffrey
VE 5spd POWER
When you ground the solenoids, you are disabling them electrically. Basically, the idea is to splice one of the wires going into one of the solenoids (either one will work since they're wired together) and attach the spliced wire to a nearby area on the car's frame. This will cut the flow of electricity to the solenoids, cutting off their oil pressure and possibly silencing them. Check Craig's site for proper instructions. Also, you may want to think before doing this, because it could be potentially harmful to your engine. If you check my recent post about VTC's (should be near the top) I have tried to explain why two mechanics have both told me not to ground the VTC's.
Matt93SE
04-08-2018 09:23 AM
MaximaDrvr
08-19-2015 08:20 PM
JonnyMax
01-25-2001 08:58 AM
