Ve30de
Re: Re: Ve30de
Originally posted by GreenMaxVE
No, I have a 94 SE and my VTC's went bad.
Re: Re: Re: Ve30de
Originally posted by subs1000w
Hi i have a 92 maxima se and was wondering what a VCT is because my car has een messing up ocasionaly its hard to explain what it does but it hesitates or jolts when excelerating and i was wondering if anywon else has this problem it also has mood swings one day it will smoke mustanges other days il loose to cavaliers and was wondering what might make my car be fast one day and slow others any replys are greatly appreciated thanks
Re: Re: Re: Re: Ve30de
Originally posted by Badaxxima
The VE30DE had variable valve timing, the VTC (valve timing control I think) is the mechanism that varies the valve timing. When they go bad, it's $$$. If it isn't that, then it sounds like your AAC valve, it controls your idle and allows more air into the engine to make power as compensation for when you turn (use power steering), brake, etc. When these go out, your car will buck violently, miss, stall, die, refuse to start and have a generally erratic idle. They aren't hard to replace. I haven't done it on a Nissan, but I've done it on other vehicles.
I've never replaced a Nissan AAC, but when I replaced the one on my dad's Chevy truck (Chevy calls them Idle Air Controllers), it was $48.95 at NAPA and located on the throttle body under the air cleaner (airbox). A search should turn up something as to it's location. The Chevrolet IAC was a cylindrical, electric, stepper-motor with four wires on it and the end was threaded into the throttle-body. Had to use a 1 inch wrench to get it out.
Well... what exactly is the part that goes bad. I'm thinking of modding the he|| out of a VE and i was going to get all custom internals and i was curious what part it was that screwed up.
Just my $0.02,
http://www.rpmonline.com/zip for some custom internal parts for anything.
Re: Re: Re: Ve30de
hi i have a 92 maxima se and was wondering what a VCT is because my car has een messing up ocasionaly its hard to explain what it does but it hesitates or jolts when excelerating and i was wondering if anywon else has this problem it also has mood swings one day it will smoke mustanges other days il loose to cavaliers and was wondering what might make my car be fast one day and slow others any replys are greatly appreciated thanks
bill99gxe
Fluids and Lubricants
72
Sep 25, 2006 09:28 PM
SteVTEC
57
Nov 26, 2002 01:42 PM
