where to run power wire??
Old Feb 21, 2002 | 07:49 AM
nastee's Avatar
i just got my trans rebuilt or $950 after it's been shot for a week, now, im about to hook up my sounds this morning. but my problem is that i cant find a hole to run the positive wire from the hood to the trunk, or do i have to drill? can someone help me?
Old Feb 21, 2002 | 08:04 AM
MaximaSpeedNYC's Avatar
Re: where to run power wire??
on the right side of your hood in the back behind the battery there is a hole, u put it through there and then it ends up being behind your fender where your right front wheel is, then open your driver seat there and stick it in, and open all of floor panel that is at the edge of your car when u open ur door and stick it all through there and continue to the back till u get to the trunk, then of course screw back on all ur floor panels and thats that, wont be a trace of a system, holla back at me if u need help, if u live in nyc ill help ya lata
Old Feb 21, 2002 | 08:10 AM
nastee's Avatar
Re: Re: where to run power wire??
i'll go and look for that now, thanks a lot
Old Feb 21, 2002 | 08:20 AM
Matt93SE's Avatar
STFU n00b!
here's a pic to illustrate what he's talking about...
(follow the big yellow wire)
picture of the large grommet behind the battey (from underneath)
http://www.ee.utulsa.edu/~mblehm/pic...m/MVC-004S.JPG
under the hood:
http://www.ee.utulsa.edu/~mblehm/pic...m/MVC-005S.JPG
hole I drilled in the firewall for the cable. wouldn't fit anywhere else
http://www.ee.utulsa.edu/~mblehm/pic...m/MVC-002S.JPG
run it right next to the stock harness. you can simply pull the factory zip ties loose and strap it in there.
http://www.ee.utulsa.edu/~mblehm/pic...m/MVC-003S.JPG
Old Feb 21, 2002 | 05:31 PM
mtcookson's Avatar
you should also run a ground right off of the battery. there is real bad distortion on some amps when you ground to the frame. it's kind of weird.
vybz05
Dec 10, 2015 07:38 PM
sake1bs
Sep 19, 2015 09:32 PM
conansriver
Sep 3, 2015 06:38 AM
Viralkill
Aug 16, 2015 05:09 PM
doobadoo
Aug 15, 2015 06:43 PM
