ecu and cams....
Old Mar 1, 2002 | 10:49 AM
pearl93max's Avatar
ecu and cams....
does anyone have the jim wolf tech. ecu upgrade or the cams they have out for our cars??? if you do...is it worth the 700 bucks a piece to invest in?? wanna get the max to run alot faster- will this help out
Old Mar 1, 2002 | 12:41 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
Re: ecu and cams....
the JWT II cams are only $550 and the ECU is $560...not $700 a piece.
Originally posted by pearl93max
700 bucks a piece
Old Mar 1, 2002 | 11:35 PM
pearl93max's Avatar
i'm soooo sorry about the price typo...my bad
Old Mar 2, 2002 | 12:42 AM
ICONOCLAST's Avatar
I have the JWT ECU w/NOS daughter board
I have the JWT ECU w/N20 Daughter Board and love it. IT has made a huge difference in my 92SE if you want to know more Im me on AOL at DJthrilla2 or post it here!
Old Mar 2, 2002 | 07:46 AM
pearl93max's Avatar
ecu
what gains do you get from the upgrade??? will the top speed change any, or will it still shut off about 120mph?? i'll im you later tonight if you're on...mine in pearl93max...later
Old Mar 2, 2002 | 11:29 PM
ICONOCLAST's Avatar
Not sure of the exact torque and HP gains, but it is very noticable. It revs faster, accelarates faster, and has my exhaust sounding right now, not raspy. I have a Warpspeed ss t-409 ypipe, RT cat, and greddy sp cat back now that sounds phat except when the ypipe hits the front sway cause my motor mounts suck *** and are getting replace in the next month, just no money now.
The JWT ECU though I have noting but good things to say bout it cept I have a problem I hink with my O2 sensor so occasionally now it will ackfire because the o2 is the original and running now 20degrees F hotter then before. The other thing is that my MAF is not fluctuating its voltage to correctly flow the right amount of air to fuel mixture.
IM me usually at 3:30am-4:30am when I am on my meal break at work is about the only time I am on!
Old Mar 3, 2002 | 12:52 AM
VTECSTALKER's Avatar
are the cams for the ve or vg?
Old Mar 3, 2002 | 12:54 AM
DA-MAX's Avatar
just the VG...
Old Mar 3, 2002 | 12:59 AM
well i guess im *** out then.
Old Mar 3, 2002 | 01:11 AM
ICONOCLAST's Avatar
Not really, look into getting custom ones made! There is a shop here locally in Lexington, Kentucky that may be able to help you if you really want cams, or a custom engine rebuild, or call Heikemian racing he might be able to help you also but for a price!
I will get the number for RTC Technology here in Lexington, Ky for you and post it or you can call information and get the number for RTC Technology here in Lexington, Ky. If you do that, talk to Stephen Jessey when you call, he is super knowledgable and has a 300zx race car and I have previously talked to him about a complete engine upgrade/rebuild!
Old Mar 3, 2002 | 01:14 AM
i may still be *** out cause i am in maryland
Old Mar 3, 2002 | 10:37 PM
ICONOCLAST's Avatar
Maryland isn't that far at all!
If I hadn't found RTC technology here i was going to go to California to get custom work done
Jared
Old Mar 3, 2002 | 10:53 PM
nismo1989's Avatar
Re: ecu
Shut off at 120?? Why would your car shut off at 120? I have been clocked at 139mph in my Maxima on SR37.
Is there something different? I don't remember how fst it was stock, I never really pushed it then, but... ?
Old Mar 3, 2002 | 11:00 PM
DA-MAX's Avatar
Re: Re: ecu
Originally posted by nismo1989
Shut off at 120??
yeah never heard of that either! I've pegged it at 125 many times, but check this shot of this VG(w/ HUD), 143mph!!!!(bone stock)-->
http://server3001.freeyellow.com/cometgst/hud.jpg
Old Mar 3, 2002 | 11:02 PM
nismo1989's Avatar
Re: Re: Re: ecu
That's out of control on a bone-stock VG. I would have never tried that stock. That's just stupid fast for ridin on marshmallows!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!
Old Mar 4, 2002 | 12:43 AM
ICONOCLAST's Avatar
I have a ve but have been past the 145mph marker and that was stock, and now getting to 145 is easy unlike before!
Jared
Old Mar 4, 2002 | 01:03 AM
i second that!!!!
Old Mar 4, 2002 | 08:47 AM
Badaxxima's Avatar
Re: Re: Re: Re: ecu
Hehehe.
1) Yes you would, he's goin' straight.
2) It's like rollin' a supercharged Caddy on a diet, if you can imagine what that's like...
Old Mar 4, 2002 | 08:56 PM
pearl93max's Avatar
top speed
if i have the gas to the floor, i can get to about 120 on the speedo and the engine will shut off....like the newer chevy trucks(i've only seen chevy trucks do this)...but the tach shows about 4 grand...it won't speed up anymore unless i'm going downhill. i've tried and tried, but can't reach over that on the speedo. at 1st i thought it was another gear, but won't go any faster. i have a 93 gxe auto....i dunno what the hell it is
Old Mar 4, 2002 | 10:03 PM
DA-MAX's Avatar
Re: top speed
something is VERY wrong with you r car, you need to have that checked out! I can imagine you telling your mechanic this... "help me, I can't do 130 in my car for some reason!!!" but seriously get that checked!
Old Mar 4, 2002 | 10:15 PM
Nismo87SE's Avatar
Re: top speed
I have an idea, when my uncle remove his center console to fix something he left the A/T switch unplugged. His car did seem slow because when it hit 4th gear at 115mph it didn't pull anymore. But he has an SE and with it on Power it peggs the speedo. Here is the vid of his 200k+ mile 91SE with 440lbs of passengers (I weigh 160lb, my cuz is just alittle heavier) http://www.vi2.com/maxForumFiles/2_4_2002/91maxima.WMV
Old Mar 5, 2002 | 09:26 AM
pearl93max's Avatar
i have an auto
mine's an auto...the speedo only goes up to 125 unlike the se which is 145...the tach almost redlines at 120 mph.....i dunno, maybe just muy car only goes that fast
Old Mar 5, 2002 | 09:39 AM
Taegost's Avatar
Re: top speed
I have the exact same car, and I KNOW I can go more then 120, I don't know exactly how fast I've gone, but judging from the needle position, it had to have been close to 135-140, and that was with a leaky exhaust!
I still say the car went faster before I had the leak "fixed"... Which it wasn't, damn scam artists...
Old Mar 5, 2002 | 12:07 PM
catman316's Avatar
Mine car cant go faster that like 130 more or less, because it have a speed limiter. It do the same think like the RPMs limit, why its that?
Old Mar 5, 2002 | 04:30 PM
Badaxxima's Avatar
Manufacturers use speed limiters to keep owners from doing things like blowing out their tires (drastically exceeding the speed rating), blowing the engine, or just putting themselves in unecessary danger. Not that WE need them.
Old Mar 5, 2002 | 09:13 PM
nismo1989's Avatar
Re: Re: Re: Re: Re: ecu
Originally posted by Badaxxima
Hehehe.
Hey, you aren't makin fun of my old caddy are you??!!! That thing was badda$$.......
supercharged LT1 Corvette engine in a 95 Fleetwood Brogham. Luxury at the speed of light, baby!!
Old Mar 5, 2002 | 09:32 PM
Badaxxima's Avatar
Re: Re: Re: Re: Re: Re: ecu
Man, you are slow! That was 2 days ago. I almost forgot about it. Just kiddin'. Did you take any pictures? Not of the engine bay of course, nobody takes pics of an engine that few people have ever seen. How did you get motor mounts and everything for that? Or did you convert it to RWD?
Old Mar 5, 2002 | 11:26 PM
nismo1989's Avatar
Re: Re: Re: Re: Re: Re: Re: ecu
Fleetwood Brogham De' Elegance. RWD auto standard. It came with the LT1 Corvette engine in it. The only modification was the Supercharger done by a guy in town known as "Cadillac Jack". You can look him up on the web. He might still have pics of it, but I never took any pics of it that I can remember. I think actually I might have taken a couple, but that was years ago and who knows where they've ended up...
Oh, and the stock motor mounts were more than enough to handle the supercharger. The lame part is that at 144mph the governor would stop the flow of gas to the injectors so that is as fast as I got to go. A new ECU could have taken care of that but I sold it when it hit 89K mi...
gigabyte
Jan 6, 2017 06:05 PM
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
Dasmith
Sep 23, 2015 08:28 PM
QueensMAX
Sep 15, 2015 04:14 AM
