New VTCs installed
Old Mar 16, 2002 | 04:51 PM
RosenKen's Avatar
New VTCs installed
I just replaced my old worn out VTC sprockets with brand new ones. I did end up removing both heads although it is unnecessary to do so to replace your VTCs. The reason I took off both of my heads was to easily drill out and replace some broken exhaust studs. I also installed a new O2 sensor while I was in there.
Want answers to all the infamous VE engine hesitation problems? Has nothing else worked? First, try advancing your ignition timing. Second, you might just have to replace your VTCs. It was worth every penny, my car is a rocket now! VE power!!!
Hit me with questions if you have them. If you're just looking for basic VTC information, DO A SEARCH and you will find all the info you need.
Old Mar 16, 2002 | 08:12 PM
bjfence
Was the hesitation that you were feeling very random across the rev range? I sometimes have great power off of the line and the engine seems to hit a ceiling at around 3500 to 4000 RPM OR I get poor low end performance, jerky acceleration but good top end.
Is this the VTC's?
How much did the parts cost you?
Thanks for any info...
Old Mar 16, 2002 | 09:10 PM
bjfence
Is this the VTC's?
Old Mar 16, 2002 | 10:21 PM
maxdout92se's Avatar
i too suffer those same symptoms....and did you say you made changing your VTC's a DIY job?? Damn i can only dream of changes those sprockets myself!!!
Old Mar 17, 2002 | 07:22 AM
MaDMaX024's Avatar
hmm...
on a scale of 1-10 (1 being putting gas in, 10 being a clutch job w/ a flathead screwdriver as your only tool) how hard is this job? i'm contemplating getting a rebuild kit and doing that myself over vacation(april).
Old Mar 17, 2002 | 07:27 AM
Nismo87SE's Avatar
Re: hmm...
I would say its a 10.9 on a scale of 1-10. I pulled the heads on my VG to do the exhaust studs and it was a PITA. I recommend you get some extra VE heads from a junkyard. That way you can replace the studs, fix the VTC, (get some headwork done if you want to ), it will save alot of downtime too. This way all you have to is pull the orginal heads then replace them with the other heads. Now you have an extra set to sell someone (sell them to me).
Old Mar 17, 2002 | 08:08 AM
MaDMaX024's Avatar
Re: Re: hmm...
$250. send me the money, in 8 weeks, i'll ship you my VE heads.
seriously though, thats what i was thinking about doing.
there are two junkyards around here that have 1 set of heads (combined). what i was thinking was this. get a spare set of heads, rebuild the VTC, send the cams to get reground (260 grind, like you said in another thread), heads ported and polished, 5 angle valve job.
before i can do this though, i need tires and my clutch replaced.
Old Mar 17, 2002 | 09:20 AM
Nismo87SE's Avatar
Re: Re: Re: hmm...
Once you get the extra heads there isn't any rush. It took me 3 months after buy my extra heads to have them worked on and installed. One thing is for sure a 260 grind for the VE's would widen the powerband about 100-300rpm. It would probably gain around 5-9fwhp at the peak and combined with P+P heads around 10-20fwhp at the rev limiter.
Old Mar 17, 2002 | 09:55 AM
MaDMaX024's Avatar
Re: Re: Re: Re: hmm...
under normal conditions, would there be a loss with the 260 grind at low RPM? i ask because, as long as the idle isnt affected too much, i could go with 270, and if the functioning VTC would offset the loss, i could deal with it. a friend of mine had some nismo cam in his SOHC 240sx. he had a HUGE power loss below 3800, but above that, it was very fast, but if i rebuild the VTC and get cams, so my low end is the same or slightly improved, and the highend is improved, i would definatly go for that.
why dont you IM me? conversing through posts is too slow.
my AIM SN is "beakmoney"
thanks
MaxLife17
Jun 27, 2019 01:37 PM
Excalibur23
Oct 13, 2015 04:33 PM
Max8
Sep 22, 2015 02:53 PM
2kmaximel
Sep 16, 2015 03:19 PM
Johnny9595
Sep 3, 2015 05:18 AM
