ECU upgrade...which one?
Old Nov 21, 2000 | 11:02 AM
ckcie
I'm looking to get an ECU upgrade for my 1992 GXE. The only other mod I've made to the engine is a K&N Air Filter.
What would be the best ECU upgrade option? Do they really make a difference? If so how much?
I know very little about this so any advice would be welcomed. Thanks!
Old Nov 21, 2000 | 12:07 PM
Matt93SE's Avatar
STFU n00b!
It does make quite a bit of difference, but I would suggest getting other mods first, before you buy the new ECU..
(the ECU is programmed to compliment the engine mods you already have on the car. )
sooo, if you're planning on adding exhaust or doing any internal engine work, do that before you get the ECU.
As for brands, the JWT is pretty much the only good one out there. stillen's ECU is simply a JWT ecu with Stillen's name on it..
Old Nov 21, 2000 | 01:56 PM
ckcie
thanks
Thanks! I'm new to this. So how much will this ECU cost if all I've done is a filter charger. Would you know this?
Old Nov 21, 2000 | 02:08 PM
Matt93SE's Avatar
STFU n00b!
the ECU itself is $550, which includes initial programming..
you can have it reprogrammed later when/if you get new mods for (I think) $100 a pop..
might as well get all your other mods done first, then buy the ECU! makes much more sense $$ wise!
Old Nov 21, 2000 | 07:59 PM
amax935's Avatar
Re: thanks
go for a hi-pro y pipe next, intake and y are the best bang for the buck. ECU upgrades are better utilized as a later stage upgrade.
Old Nov 22, 2000 | 09:50 AM
ckcie
Anyone know anything about JET ECU TUNING UPGRADES? Are they any good?
Old Nov 22, 2000 | 09:56 AM
Jeff92se's Avatar
I'm needing a caw
Do yourself a favor and stay away from JET ecus. I think Dinan makes one for our 3-gens but I have no idea how they compare to JWT(which is probably the best one out there)
gigabyte
Jan 6, 2017 06:05 PM
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
cruce91
Sep 20, 2015 10:23 AM
QueensMAX
Sep 15, 2015 04:14 AM
