VG Turbo Idea Group Deal
Mar 31, 2002 | 09:06 PM
  #41
matt are you telling him to go kill himself?
Mar 31, 2002 | 09:17 PM
  #42
Quote:
Originally posted by Matt93SE
Dude, if you think this is a DIY job, you need to stick your head in a plastic bag, rubberband it around your neck, and go for a run around the block.
now thats a classic, a ****ing classic!!!!!!
Mar 31, 2002 | 09:25 PM
  #43
Quote:
Not at all. I'm merely proving that Darwin was right. The problem will one day take care of itself.
Mar 31, 2002 | 09:27 PM
  #44
damn matt, alittle too much sugar for you today eh?
Mar 31, 2002 | 09:28 PM
  #45
ah yes. I see said the blind man.
Mar 31, 2002 | 09:32 PM
  #46
Well, if your gonna run low boost < 8psi esp., or even high boost, you dont neccesarily have to use Nissan parts, you can buy aftermarket products for some things. Just because theres not an exact bolt on kit, dosen't mean theres nothing.It usaully a good idea not to use anything older, or more used than the engine that is already in your car. Thats just an idea though.
Mar 31, 2002 | 09:33 PM
  #47
Quote:
more like lack of sleep, and I'm tired of trying to teach people here common sense. (My Spock-logic says that if it involves removing the engine and costs more than $3000, it's probably NOT a DIY job.)
Mar 31, 2002 | 10:09 PM
  #48
IBTL
Mar 31, 2002 | 10:50 PM
  #49
Know your limits and know what you're talking aboot! Some jobs are easy, some are obviously hard, and some sound easy in principle but ARE hard! (ie, the phrase, "Just drop in a turbo engine!")
Mar 31, 2002 | 11:23 PM
  #50
im sorry, but i dropped a turbo in my car before, i had the pic but it wont let me link anymore. see its the oen thats supposed to be in my sig.
Mar 31, 2002 | 11:24 PM
  #51
Quote:
Originally posted by mtcookson
ok, i get it. it won't really matter for me though because i just want to swap the z31 engine. that will be easier than trying to find a kit from the looks of it.
why dont u just use z31 manifolds and turbo from the junk yard.. bolt everything up, run a few lines here and there.. and run like 4 lbs of boost, say you have a turbo and be have it... or just buy a honda and a drag turbo kit
Apr 1, 2002 | 01:45 AM
  #52
Quote:
uhh, buying a turbo from a junkyard wouldnt be very smart....neither would buying a honda
Apr 1, 2002 | 01:53 AM
  #53
Quote:
honduhs rape yo, especially with the two big bottles
Apr 1, 2002 | 01:56 AM
  #54
how are the z31 injectors and ecu totally incompatable?? they are the exact same engines minus the T at the end of the z31 code VG30ET=z31 VG30E=maxima...
That is because the Z31 uses the old 8-bit prom and the ECU connector/output pins are totally different. Now a Z31 ECU/injectors will work in a 2nd gen maxima but not 3rd gen. A Z32 ECU would work in a 3rd gen VE however (I doubt it would work in the VG considering it uses a distributor). The only thing that is the same from the VG30ET vs VG30E is the block (unless its a Z31 4/87 build). The pistons, rods, crank are slightly different as are the heads and IM.
Apr 1, 2002 | 02:06 AM
  #55
LMAO. Now that is Teh funnie
Apr 1, 2002 | 04:06 AM
  #56
you still have to fab up the entire intake and exhaust, just as you would if you were doing a custom install on your stock engine.. and you still have to get the ECU to work on boost.
you'd be best off just buying Z31T manifolds and turbo, bolting it on, then having a shop build the intake and exhaust tubing for you, then let JWT worry about the ECU. get some bigger injectors and tell them what kind you've got. they'll make the ECU work with the injectors you've got.
that's pretty much it. the rest is tuning.
tuning? you mean with one of these?
