Tps?
Old Apr 9, 2002 | 08:11 PM
jaredb03's Avatar
Tps?
How many ohms is the throttle position sensor supposed to be set on, on a 92 SE. Also if says no ohms when you check it does that mean it is bad. I'd appriciate it if you could help. Thanks in advance
Old Apr 10, 2002 | 05:05 AM
Taegost's Avatar
Re: Tps?
I don't know much about the sensors, but if it reads 0 Ohm, that means it has NO resistance... You'd get the same effect if you put a piece of copper wire in it's place.
If it's over 1M Ohm, usually it's open, which is like taking it out completely... Usually, some things actually require over 1M Ohm, but I have no clue what practical applications that would have outside of extremely high-voltage applications...
Roymg
Sep 3, 2018 05:10 AM
schmellyfart
Sep 25, 2015 04:47 PM
sake1bs
Sep 19, 2015 09:32 PM
nizmolee
Aug 22, 2001 12:34 PM
