HELP! cant turn key, wheels or ...
i just took apart my dash as ive done before to replace the lights behind the gauges, ok so i put everything back together and then reconnect the battery but now i cant turn the key the wheel is locked cant shift and the brake pedel is impossible to push in, Somebody please tell me how to correct my problem.
i have had the steering wheel lock up before and usually you can turn it just a tiny bit and then you are able to turn the wheel but thats not the case this time. any possible solutions will be greatly appreciated. thanks
It sounds like the safety lock on the steering wheel...You can move the wheel a little and then it will allow you to turn the key. Most of the time if it is where it is hard to turn it is because it is in a bind and is barely locked and causing pressure toward the lock side.
See if you can wiggle the wheel back a forth (it should move just a tad and take pressure off the key assm.) and that will allow you to turn the key which will unlock the wheel.
hope this helps.
hope this helps.
thanks for replying shortly after i posted i was able to get it unlocked, but i couldnt get on the org to say that i had figured it out. yeah i have my steering wheel lock before and usually there is a little movement but this one was solid but i just had to pull the wheel way over and then turn the key like you said, it just didnt seem to work for me the first few times, then i was like what the f%ck. but its good to know you have a place to turn when you have silly questions.
Maxima30
09-07-2015 06:13 PM
